where can i get alignment specs
Old Mar 21, 2002 | 11:53 AM
'00WhiteLightneeen's Avatar
Question where can i get alignment specs
does anyone know the alignment specs for a 2000 L?
-Mike
Old Mar 21, 2002 | 12:52 PM
WrongdayJ's Avatar
I got the alignment specs for my '99 from SVT.
1-800-SVT-FORD
Later,
Old Mar 21, 2002 | 01:59 PM
redlightspecial's Avatar
I've got the specs printed off at home. I'll have a look for them and post the numbers. I have the stock, preferred and autocross specs. I pulled it off of a thread here some time ago. It's probably around page 75 by now!
Old Mar 21, 2002 | 02:38 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Printout sitting on my desk.
Lightning Spec:
LH Caster: 6.9, +/- 1.0 deg
RH Caster: 7.4 +/- 1.0 deg
LH Camber: -0.5, +/- .7 deg
RH Camber: -0.5, +/- .7 deg
LH Toe: -0.05, +/- 0.15 deg
RH Toe: -0.05, +/- 0.15 deg
Lightning Preferred:
LH Caster: 6.7
RH Caster: 7.2
LH Camber: -0.5
RH Camber: -0.5
LH Toe: -0.05 (slight toe in)
RH Toe: -0.05 (same)
Old Mar 21, 2002 | 02:51 PM
DHFerguson's Avatar
Search engine, search engine, my kingdom to have the search engine working again!
Look here:
https://www.f150online.com/forums/sh...threadid=69815
This info needs to be added to the FAQ!
Old Mar 21, 2002 | 03:40 PM
easterisland's Avatar
I don't know a lot about alighnments, so I figured this is the place to ask. Do I need to use different specs for a lowered Lightning than the ones posted above? I would think there is no difference,b ut I want to make sure. Thanks.
Old Mar 25, 2002 | 03:02 AM
thanks guys! Now I can take it back to the shop and have them align it right (instead of for a regular F150).
Old Mar 25, 2002 | 06:38 AM
SLVRLTNG's Avatar
Bob,
where did the "Lightning preferred" specs come from?
thanks, JR
Old Mar 25, 2002 | 08:03 AM
JR,
Not sure who created the preferred specs but they've been in my "L tech" folder for at least a year and a half.
Bob
Old Mar 25, 2002 | 08:37 AM
Chikenears's Avatar
Has anybody used these "Preferred Lightning" specs on their truck, and how did it drive? Was the steering wheel centered like it's supposed to be?
I lowered mine 2" front and rear. Are these specs intended for a L that's lowered? Just making sure.
Old Mar 25, 2002 | 02:41 PM
DHFerguson's Avatar
Had mine alligned to "Lightning Preferred' last year to try and fix the tendency to wander in the ruts created by the HEAVY trucks here in Michigan. 164,000 pound gravel trains and steel haulers make deep 'channels', typically in the right lane of asphalt paved roads. My truck would wander so much it would take all my attention to keep it in the lane. Works good now.
BTW - Herb just e-mailed me that he has a new supply of lower control arm washers machined. Checks in the mail.
