Lightning CD Changer Studs
Old Mar 21, 2002 | 01:08 AM
FlashSVT's Avatar
Any tips for removing the (4) studs that hold the CD Changer in a Lightning? I'm assuming they are welded like the two studs that hold the storage bin.
Before I dig in tomorrow, I was wondering what some of you guys have done to remove them.
Thanks,
Wayne
Old Mar 21, 2002 | 01:12 AM
ICULOKN's Avatar
I have not removed mine yet, But I might with the Thuderform in there now. I would grab them with a set of Klien's or linemans pliars and break them off....
Old Mar 21, 2002 | 01:34 AM
BlownSVT2001's Avatar
One quick smack with a ball-peen should do the trick...at least it did on mine!!!
Old Mar 21, 2002 | 02:28 AM
z96Cobra's Avatar
Dremel, small cutting wheel, and a VERY steady hand... those little thigs go zoomin' when they break!!! lol
Roger
Old Mar 21, 2002 | 08:17 AM
DennisWeise's Avatar
Yes, Grab them with a Kleins straight up, push back and forth a few times and the weld will snap off. You won't have to remove any of the 3 tool box bolts for the Thunderform to fit. I just put some fender washers and nuts back on to cover the holes in the carpet.
Also, I drilled holes and used bolts for the Thunderform instead of the screws. A couple of 3/8" x 4" carriage bolts do a real nice job and would make it a lot harder for someone to steal the subs.
DW
Old Mar 21, 2002 | 08:22 AM
01Lightning's Avatar
What is this Thunderform you guys are talking about? A sub box?
Old Mar 21, 2002 | 09:45 AM
Edward's Avatar
I just cut mine shorter with a Dremel last night. I left them long enough so that if I want to return the changer to the stock location, I can. They are still short enough not to rub the bottom of my Thunderform because the carpet and jute is pretty tall.
HTH,
Edward
