Removing stock fan
Old Mar 19, 2002 | 11:31 PM
LatemodelRacer2's Avatar
Removing stock fan
I atempted to take the stock fan out of my truck today so i could pu my electric fanin. But when i went to take it out it was harder than it sounded. How and where do i unbolt it? i tried te pulley that dint work i trie fornt that didt work. Any suggestions welcome
Old Mar 19, 2002 | 11:54 PM
ICULOKN's Avatar
Re: Removing stock fan
Um what did you try to do??
Old Mar 20, 2002 | 12:54 AM
owheelies's Avatar
You need a 1 7/8" wrench! Scoll down on the link. http://www.teamjdm.com/id247.htm
Old Mar 20, 2002 | 01:29 AM
CHIKIN1's Avatar
Dude, you don't need a 1 7/8 wrench, just use a big crescent ( or however you spell it ) wrench!!! Put a pull-bar inbetween the bolts that mount the pulley to the waterpump to keep the water pump from rotating, and try giving it a hard turn...Its a Bizitch, but it'll come off, may take a couple of tries!!!
Good Luck!!!
Black '01
Born on 5-3-01
#3603 of 6381
K&N Box Filter
Sean Hyland 2# Upper Pulley
JL 3# Lower
JDM Boost Bypass
PSP 4-Way Autologic Chip ( Tow, Street, N20 Street, N20 Track )
PSP Electric fan&CobraR water pump
PSP Longtubes w/Twin Magnaflow
PSP FactoryTech Valvebody
PSP Deep Tranny Pan
PSP DriveShaftLoop
PSP Nitrous Plate
Nitrous Express 50-150 EFI Kit
NGK / BR7 spark plugs .036gap
Mickey Thompson ET-STREETS
Old Mar 20, 2002 | 09:37 AM
NeedFourSpeed's Avatar
I think 2001 - 2002 may take a different size wrench 1 7/16??? Also, is it reverse threaded?
I haven't put mine on, I want to get the new wiring harness from JDM.
Old Mar 20, 2002 | 09:56 AM
Silver-Bolt's Avatar
Not reverse threads. 99-00 wrench size is bigger than the 01-02. Use a large screw driver or pry bar between the pulley mounting bolts. I used a large pipe wrench on mine and popped it loose. Don't unscrew it all the way until you have the schroud loose and ready to come out. Also easier if you undo the top tranny cooler line at the radiator. You will have to hold the schroud as you unscrew the fan then slip them out together. Not as bad as it sounds.
Old Mar 20, 2002 | 10:13 AM
easterisland's Avatar
If you have an AutoZone in your area they will loan you a fan removal wrench.
Old Mar 20, 2002 | 10:14 AM
That's right Silver-Bolt; I think I was thinking of the threads on the pulley.
Old Mar 20, 2002 | 11:19 AM
Don's Bolt's Avatar
I used a big Vice grip to hold the shaft coming off the water pump. The used a big adjustable wrench to break the fan loose.
If I remember correctly you turn it towards the passenger side of the truck.
It worked awesome for me.
Old Mar 20, 2002 | 04:45 PM
does jdm sell the wiring harnes that is controlled by a/c that i could buy separetley from the fan.beacause i already have a fan.
Old Mar 20, 2002 | 05:00 PM
MotorcycleMan's Avatar
Does the electric fan hurt towing? (the same or changes it in any way) I'll be towing around 2,000lbs, 6'by8' box trailer W/two bikes.
Thanks in advance.
And I think my 100th post!!!
Took me long enough.
Old Mar 21, 2002 | 02:41 PM
I don't see how the fan could hurt; in fact when you need the fan it pulls even more cfm than the stock fan.
Old Mar 21, 2002 | 04:11 PM
J15BIG's Avatar
thats a big wrench
Old Mar 21, 2002 | 04:57 PM
Autothrottle's Avatar
The elec. fan will not hurt towing at all.
Does anyone know what JDM rates thier fans at? ( cfm )
