Transmission question inside
Old Mar 18, 2002 | 04:46 PM
papabear's Avatar
I need to know if the transmission case for a lightning is the same as a power stroke engine. Buddy of mine got a power stroke into his scrap yard today and wants to know if I want the trans as a spare to build later. Does anyone know if it is the same case and bolt pattern? Any help is greatly appreciated.
John..
2000 Silver Lightning
Old Mar 18, 2002 | 05:02 PM
L in Detroit's Avatar
same trans, diffrent internals..
will bolt on but will not hold up in a lightning..
i was told that to upgrade one to the internals u can buy a new one from ford for about the same price.. ford price about 2600.00
jim
Old Mar 19, 2002 | 04:27 AM
Factory_Tech's Avatar
The case is different, but most of the internals will work, I upgrade a few of the parts, if it's a 98 or newer you're almost halfway to a monster box. The direct is a 5 plate (L gets 4) the planets on a 98 and newer are the 6 gears, you need a balanced forward drum and use better plates. Teh accumulator needs to be recalibrated and the converter isn't a good one for an L the K factor is different. If it's cheap, get it and I can prolly set you up with a conversion.
G
Old Mar 19, 2002 | 08:26 AM
papabear's Avatar
Factory_Tech
So let me see if I understand. It's case will not work but I can use the internal parts out of the transmission to rebuild the current one in my truck? Price is not a problem, It's a rollover and he already has a buyer for the engine but they do not want the trans (the buyer has a manual trans) So the transmission is mine for 50.00 just to cover the cost of the guys pulling it out of the chassis. Let me know if I am understanding this correctly. What I was looking to do was build a complete new transmission and have it ready to swap in. That way the truck would not be down for a long time waiting for the current trans to be rebuilt. Plus after years of racing I like to have spare parts around. Thanks for the input on the question.
John..
