When to use synthetic oil??
Old Mar 16, 2002 | 06:23 PM
motoxracer21's Avatar
Hey guys, my L is due for an oil change and I wanted to know when it was safe to use synthetic oil?? Or is it??
I have about 6,500 miles right now...
thanks!
Old Mar 16, 2002 | 07:02 PM
blownlightning's Avatar
Most say Betweem 8 & 10K, I used it at 7K & it's been fine but,use 10/30 Mobile1 not 5/30 Just My.02! Brian
Old Mar 16, 2002 | 07:05 PM
Mondo1's Avatar
Now would be a good time.
Old Mar 16, 2002 | 09:13 PM
ib fast's Avatar
Most would say 8-10k and are full of sh*t. Anytime after 1 k is fine to change to synthetic oil. My motor is living proof that 1k is long enough to wait,possibly sooner.
My motor was tore down for upgrades at 29.9k with 200 passes at the strip,the first of which was under 500 miles. I drove the truck like i stole it from the time it left the dealer lot.
My motor was found to be in excellent condition whith the bearings looking brand new and the only wear to be found is the coating they put on are stock federal mogul pistons. This one piston were the coating was pretty much wore off[which is normal] was within 5 thousanths clearance and factory spec.
My dyno oil was changed at 500 miles and changed to mobil one 0w30 at 1k and every 3k after,somtimes sooner. So unless these experts that tell you you need to wait have proof,and there is only one way to prove [tear it apart at 30k] it. Then don't listen too the sheep that are using the rules from old technology to back up there statements. Seeing is beleiving and everything else is speculative b.s.
Old Mar 16, 2002 | 09:29 PM
2002 SVT F150's Avatar
Many new high performance vehicles come with Mobil 1 synthetic from the factory. All MB AMG's, C5's & others.
Old Mar 16, 2002 | 10:09 PM
ib fast's Avatar
Not to mention porches[spell] and i think vipers.
I speculate that you could run sytnth with a new L motor but that would be a waste as everyone should get rid of the metal shaving filled original oil by at least 500 miles imho.
By the way,my tranny was tore down at 29k and also looked to be in new condition. I credit changing the fluid at 1k and two more times within the 29k for the tranny clutchpacks ect looking new but i also think my motor and tranny were built on a good day at the factory When we abuse are trucks,it is always a good idea to change the fluids more often than what is recommended.
Old Mar 16, 2002 | 10:18 PM
I B Fast how much proof do you want,I have preformed many tests on the lightning oiling problems lately.And try to pass on my findings!I'm glad your engine lucked out!How ever a lot of them have not.I remember when I worked for GM & we had to recall all Vette's Because they were not seating the rings as a result from synthetic oil.Granted I agree 1k should be OK for synthetic But, the 5.4 has proven many wrong! My 00 got synthetic at 2k & my 01 at 3k The 00 did'nt make a peep the 01 Had marbles in a
can!)02 Was done at @ 7k And has been fine. Your the Shepard were the sheep,You have the new technology We have the old!We are R&D men You are a PAINTER!
Have a nice day
Old Mar 16, 2002 | 10:49 PM
ib fast's Avatar
Have a nice day
I base my info on fact and what my engine builder and i have seen first hand,what is yours based on? As far as the 01's,it is pretty obvious that at least some of them have weaker engines and trannys than the 99-00's and a bigger failure rate to go along with it. But that has nothing to do with when or if you should use synthetic oil and neither does your experience at generous motors. So unless you have an engine that was tore down in good working order and can relate that to the do's and don'ts of sythetetic use then please do not feed the sheep I don't claim to be an expert or a shepard lol. Nor do i want to be but the fact is tearing down motors is the only way to judge whats happening to the internals.Don't shoot the messenger
Old Mar 16, 2002 | 10:54 PM
Odin's Wrath's Avatar
It may or may not be OK to run synthetic right away. It is, without a doubt, not going to cause any problems to run regular oil for the first 10,000 miles. What is the friggin' hurry to get synthetic oil into your engines?
I've seen commercials on TV where they put Prolong into an engine then removed the oil pan, put it on a lift, and ran it for 20 minutes with a water hose spraying the crank shaft. No damage to the engine. this seems like proof that Prolong works; but, would anyone run this stuff in their engine? No? Well, why would we stop running a regular motor oil in our vehicles, during break in, just because some wild eyed zealot for synthetic oil says it's OK because he did it and it worked out for him.
You say we're full of ****. I say you are the one with poop breath and brown eyes. And what's this fascination with sheep. 'Sounds like a personal problem to me.
Old Mar 16, 2002 | 11:08 PM
ib fast's Avatar
Another freakin expert eh, well if this is going to turn into a battle of whits then i quit because i refuse to do battle with the unarmed. This discussion has nothing to do with when or why one should use synthetic oil but rather discounting people who speculate on how long to wait to run it...duhhhhhhh
If said experts...the ones who speculate on when or why to use sythetic don't like it. tuff sh*t
Old Mar 16, 2002 | 11:42 PM
Old Mar 16, 2002 | 11:53 PM
I B, Who took the shots at the messenger? Am I an expert yes are you No,you said it not me! Do I speculate no, do I prove my findings yes.Generous Motors had problems as well as Ferrari w/ synthetics.How do I know this Oh ya I worked for them too,I just try to help people who ask,not start (as you say *****) You Remind me of Spiro except I liked him & he new what he was talking about. I'm sorry you don't like what I have to say even if it is fact.
You should stay away from sheep.It's bad for you !!!!!!!!!!!!!!!!!!
BAHHHHHHHHHHHH BAHHHHHHHHHHH BUY.
Old Mar 16, 2002 | 11:58 PM
Holeshot's Avatar
I agree that waiting a little longer does not hurt anything. 1K miles for synthetic scares me that my motor would never get full break in.
I'm changing now, at the preplanned 15K miles.
Old Mar 17, 2002 | 12:07 AM
L iminator's Avatar
Burn
My dad told me he used to use Mobil-1 when it first came out ,25-30 years ago. Put in all his new cars, then realized he could"nt afford $5 a quart motor oil every 500 miles ( mobil was very proud of their new oil in the 70"s. The point is , rings that never seat cost $5 every 500 miles. I"ll stick with Dino. PS- my dad also pointed out I could have bought 2 XL F-150"s for what I paid for the L.
Old Mar 17, 2002 | 12:10 AM
Holeshot 15K is good, any time after 8K is fine,However you are a smart man! Best of luck! Brian
