what to clean PCM with?
Old Mar 16, 2002 | 02:00 AM
slvrbolt's Avatar
i have scraped my pcm three times now and each time i swear that there couldn't be anymore goop on it. but i still have small problems from time to time. anyone have any suggestions on something that will break down the goop for easy removal?
Old Mar 16, 2002 | 04:30 AM
clonetek's Avatar
i used a pencil eraser to get all the stuff off mine.. if you scrape too much, there is a chance that the contacts will get screwed up.
i lightly scraped the contacts, then used a green brillo pad, then a pencil eraser. followed up with rubbing alcohol. do it in the bright sunshine, you'll see stuff that you've missed before.
hope this helps,
brooks
Old Mar 16, 2002 | 07:57 AM
Miami L's Avatar
Just what clonetek said. Just take your time.
Good Luck
Old Mar 16, 2002 | 08:20 AM
jarmstro's Avatar
Re: what to clean PCM with?
Are you taping the chip on? If not be sure and do so.
Old Mar 16, 2002 | 09:05 AM
Don's Bolt's Avatar
I use a Jewlers screw driver, or a eye glass screwdriver to scrape the terminals. Then the little scotch btite pad, then a use a alcohol wipe to do a final cleaning.
Old Mar 16, 2002 | 09:31 AM
SLVRLTNG's Avatar
I did EXACTLY as Don did above.. Worked perfect the first time. I took my pcm to the dining room table and took my time. Took about 15 or 20 minutes, but I only had to do it once. MAKE SURE YOU CLEAN BOTH SIDES OF THE CONTACT also used a couple of narrow strips of duct tape to hold the chip in...
hope this helps...............JR
Old Mar 16, 2002 | 09:36 AM
Chikenears's Avatar
Thumbs up
I did exaclty like Clonetek and it cleans the contacts perfectly.
Old Mar 16, 2002 | 11:54 AM
ib fast's Avatar
Laquer thinner and a q-tip and presto
Old Mar 16, 2002 | 04:01 PM
slvrbolt's Avatar
thanks i think i got it all this time i scubbed with a towel and some alcohol for about 10 mins and got a lot off. so hopefully that will be the last time.
