What Pressure To Run With ET Streets?
Old Mar 16, 2002 | 12:54 AM
BlownSVT2001's Avatar
Question What Pressure To Run With ET Streets?
I just bought a set of ET Streets and was wondering what pressure to run for the best traction? I have Jays Truck-Tracs as well. Any suggestions would be appreciated. Thanks
Old Mar 16, 2002 | 11:39 AM
ttt
Old Mar 16, 2002 | 01:49 PM
Spade$'s Avatar
i pump mine up to 14.5-15 cold. then they'll heat up to about 16-16.75. If you dont have them bolted into your rims you can't run any lower or you'll slip inside your tires
Old Mar 16, 2002 | 01:52 PM
Johnny AC's Avatar
tire pressure
I run them @ 17 or 18 lbs. and pull 1.71 60 ft. times. John H.
Old Mar 17, 2002 | 12:50 PM
bobcmt's Avatar
Best pressure will depend on rim size, but I and others have made big improvements in 60' times by increasing pressure to 20-24 lb. Find a clean spot of pavement and do a burn - you want even burn/color across width of tire mark.
Bob
Old Mar 17, 2002 | 01:59 PM
ASVTFordBoy's Avatar
I agree, 20-24 at least. I was running at 18-20 psi, but as my MPH got better, my truck started to get unstable at the top end. And almost uncontrollable with even a slight crosswind. I ran my best E.T. to date (check sig) at 26 psi, but traction was iffy.
Old Mar 17, 2002 | 02:24 PM
StruckBy99's Avatar
20-24 pounds is right on, but youll have to find what works best for your truck at your track.
4 pounds is a big difference.
I used to stay at about 18-20 until I read that little article in MM&FF with JDM putting his suspension upgrades on their L.
Too low of pressure actually makes matters worse when you involve axle wrap. My truck at 18#'s would hook for the first 2-3 feet, spin, and then hook again. Brought the air pressure up a pound at a time until the truck was consistent off the line. Now I run them at 22 and bring it up if it needs it.
I've had sub 1.7 60ft times on the 10 inch ETs ever since.
Hope this helps
Jason
Old Mar 17, 2002 | 02:51 PM
BLackBoLT99's Avatar
Suspended For Rules Violations
You guys also have to realize Blown will be running at the infamous slippery California tracks. With mine, I noticed the lower the pressure, the better hook up I got. I run mine at 14-16 psi and getting consistant 1.8x 60 ft. (which seems to be good around here.) Track prep, weather conditions will play their part in hooking up as well. Best thing to do Blown is experiment with tire pressures and see what works best for you. Start high and work your way down, checking your tire pressure and raising it or lowering it accordingly.
Old Mar 17, 2002 | 03:31 PM
Blown93's Avatar
Dont have any yet on my 2002 but my e.t. streets on my 93 i ran 18-20 best i got was a 1.83
Blown 93 Lightning
1.83
13.2
102.00
True Blue 2002 stocker
2.0
13.1
102.00
Old Mar 17, 2002 | 04:27 PM
lightning Jeff's Avatar
I always run between 12 and 14#'s when cold. Hooked best on my truck that way.
