4 program VS. 2 program chips
Old Mar 15, 2002 | 04:08 PM
StrikesTwice's Avatar
K, I've finally taken a step to the plate. I'm going to order my chip (finally) and was curious why some of you have chosen 4 program, or 2, or even single programs.
Thanks.
-Ian
Old Mar 15, 2002 | 04:11 PM
Lightning Boy's Avatar
Current Chip:
PSP 4-Way:
1.) Street
2.) Hot Street
3.) Hot Track
4.) Nitrous Track
Old Mar 15, 2002 | 04:20 PM
WrongdayJ's Avatar
I'm kinda curious about this 'hot street' and 'street' stuff.
What is the typical diffrence in these two modes?
Is is A/F, timing, transmission cut, what?
Old Mar 15, 2002 | 04:47 PM
ditto
and which would use while driving on the street? Street, Hot Street, Beat Street, Street Sweep??
Old Mar 15, 2002 | 04:57 PM
usahooters's Avatar
I got the single program because thats all I need. If I had a four program chip it would stay in the HOT zone all the time anyway. hehehe
Old Mar 15, 2002 | 05:02 PM
Im not sure exactly what all Sal does with the differant modes. But here is what I can tell:
1.) Street - No 4 Cyl. cut out, firmer shifts, alittle on the timeing, and 3.73 gears.
2.) Hot Street - No 4 Cyl cut out, firmer yet shifts, alittle more on the timeing, and 3.73 gears.
3.) Hot Track - No 4 Cyl cut out, agressive shifts, agressive timeing, and 4.10 gears.
4.) Nitrous Track - No 4 Cyl cut out, agressive shifts, timeing for the nitrous, and 4.10 gears.
We run it everyday on program one, unless we have some Torco in the gas tank from being at the track then we use program two.
Old Mar 15, 2002 | 05:07 PM
Boostin01L's Avatar
You change your rear alot?
Old Mar 15, 2002 | 05:09 PM
No, we changed out the 3.55 gears for 3.73. With the 28" tall F1's, the effecive gear ratio is 3.73. But with the 26" tall M/T ET Streets, the effecive gear ratio is 4.08, but we round it up to 4.10.
Old Mar 15, 2002 | 05:14 PM
Boostin01L's Avatar
ohhh thanks
Old Mar 15, 2002 | 05:18 PM
WrongdayJ's Avatar
I don't think I like the idea of having all those extra 'seldom used' programs sitting there that I paid good money for.
It's either on. . .HOT (not kinda hot, or semi-luke warm hot),
or it's off. . .STOCK. (No chip in the darn thing)
But that's just me.
Old Mar 15, 2002 | 10:06 PM
cool, thanks. Anyone else care to add?
Old Mar 16, 2002 | 01:38 AM
D_Coburn's Avatar
As far as I am aware the only 4-way chip is the autologic chip from PSP???? Additionally, I believe that the autologic chips are the only ones in which the program can be changed while the truck is on. With the superchip you have to turn the truck off, flip the switch and then turn it back on. I don't know about you, however, I drive around in the stock setting, and I want to be able to switch quickly when the need arises - not that I race on the street or anything.
