Air Box Mods
Old Mar 15, 2002 | 07:53 AM
ally69's Avatar
Air Box Mods
For those that widened there fender hole. Do you do both the inner and outer hole or just one? Also what did you use to do it?
Old Mar 15, 2002 | 09:31 AM
93Cobra's Avatar
I marked the footprint of the rubber hose to the fender with a paint marker. I took the airbox completely out, and then got a die grinder to remove the excess material from both the inner and outer hole. Be careful on the outer hole - if you slip, then you will hit the actual fender skin... which wouldn't be good. After doing this, prime it, paint it and you are back in business.
Old Mar 15, 2002 | 10:04 AM
awhittle's Avatar
The Huge hardware stores have a high speed air saw that is known as a body saw that goes thru like butter.
Andy
Old Mar 15, 2002 | 10:25 AM
01Lightning's Avatar
Was the hole made larger on the 2001s? I was wondering if I could benefit from this...
Old Mar 15, 2002 | 10:35 AM
LIGHTNINROD's Avatar
You should see the 'hole' in my fender. Masterloggie(2000 L) and I compared his to mine. The 2000 is smaller in diameter but has a nice rolled-edge to it. Mine looks like somebody at the factory took a hack saw to it--rough, jagged edges(painted, though) and a slightly larger diameter .....
Dan
