Tr5's gap, and the SnapOn Socket-
I know this has been covered before, but wanted to find out what the correct gap on these is? Don't want to go thru the pain in the butt of putting them in if I don't have them gapped properly, obviously.
Also, I'm looking at purchasing the SnapOn socket (can't remember the part number) but wanted to see if there was any feedback from current owners? Did it make a big difference? Would you spend the $50+ to buy another one if you lost yours?
Thanks!
Chris
Thanks!
Chris
I used to have a list. I use an old piece of hose to start threading the new spark plugs. I use a 1/4 inch ratchet along with several extensions. I also have an adapter for a 1/4 to 3/8 so my deep socket will attach to the extensions. I have a swivel 7mm socket also to remove the coils. I have an extension magnet which I use to remove the plug.
Are you talking about the 7mm 1/4" drive swivel socket for removing the coils on the plugs? If so you can get them off the tool truck for under $30. I didn't need any other special tools to do the job.
