Headlight Switch Question?
Old Mar 12, 2002 | 11:00 PM
bobb's Avatar
Question Headlight Switch Question?
This may be a dumb question...but does your headlight switch light when the lights are on? In other words, is it illuminated like the controls for the heating/AC? Just the little part in the middle that functions as the pointer for the switch....mine has never lit and I think that it should....thanks.
Old Mar 12, 2002 | 11:06 PM
SacGyver's Avatar
Yea... it should be lit. If it's the only thing not working, then its definately not a fuse.
If the bulb is burnt out, then you're lookin at a whole new switch assembly, unless you can somehow crack it open and put it back together.
Old Mar 12, 2002 | 11:07 PM
bobb's Avatar
Good, I am hopeful that this will be a quick warranty item....wish me luck.
Thanks, for the quick reply!
BB
Old Mar 12, 2002 | 11:12 PM
VINNIE's Avatar
NO
The switch does NOT light. The little characters around it does but not the switch.
VINNIE
Old Mar 12, 2002 | 11:28 PM
bobb's Avatar
Ok, so now I am really confused , here is a diagram of the switch:
https://www.f150online.com/galleries...y.cfm?gnum=918
Not sure if it will be readable....but I do see a bulb in the diagram, so it is only for the areas around the switch, not the pointer itself?
BB
Old Mar 12, 2002 | 11:38 PM
VINNIE's Avatar
I did the headlght mod
I had 2 switches in my hand (one from the truck and one I bought from the dealer to modify).Neither had a light for the ****.The **** is just clicked on to the switch.
I just went downstairs and got my other switch(it is in my hand).The **** is solid and does NOT light.
Hope this helps
VINNIE
Old Mar 12, 2002 | 11:40 PM
bobb's Avatar
Thumbs up
Vinnie thanks! No trip to the dealer for me....it is working (not lit) as designed...
BB
Old Mar 12, 2002 | 11:44 PM
VINNIE's Avatar
Bobb
Glad I could help and keep you from going anywhere near a dealer.I cringe when I drive by my dealer.
VINNIE
