N20 install question
Old Mar 12, 2002 | 03:06 PM
Spade$'s Avatar
Where the heck do I tap the fuel lines into? In the instructions it says sometimes there's a little black cap on the rail? No luck so far. If not that cap where the heck should i throw in that little T joint?
Mark
Old Mar 12, 2002 | 03:12 PM
Spade$'s Avatar
nm i found it ... now the question is... what do i use for the 12V power source?
Old Mar 12, 2002 | 03:18 PM
ICULOKN's Avatar
You can make your own sources from the battery or get in the ignition circuit at the steering collum. Just besure to check everything with a meter before you splice into it....
Old Mar 12, 2002 | 04:17 PM
Spade$'s Avatar
thanks IC but new problem.... the fuel line that i WAS going to tap into is way too small an outlet.. on the passenger side back under a few hoses. Is this where im suppost to tap?
