Smoke at startup..normal??
Old Mar 12, 2002 | 11:31 AM
JLightning's Avatar
Question Smoke at startup..normal??
I know this has been covered about 1.2 billion times, but is it normal for the truck to smoke at startup? It just started doing that for the first time, and I just got a new exhaust setup (mag 12468). So just checkin to see if I need to worry about it...thanks!!
--Jeff
Old Mar 12, 2002 | 11:32 AM
01Lightning's Avatar
Hey JLightning, how many miles are on your truck and what kind of oil are you using?
Old Mar 12, 2002 | 12:06 PM
LIGHTNINROD's Avatar
J:
Could be condensation or an overly 'rich' condition--wouldn't worry about either one. May be unwanted oil in the intake area? Not what I consider 'normal' but just about everyone has it. Undo the clamp that holds the rubber boot to the th/ body and move the boot back a little bit. Oil will probably be puddled or dripping past the th/plates.
Dan
Old Mar 12, 2002 | 12:57 PM
99Zeus rtrns's Avatar
do you have a chip? Mines did the same thing...I took my chip out and recleaned my contacts and never happened again..I have no clue
Old Mar 12, 2002 | 05:57 PM
JLightning's Avatar
I have about 12K on my truck, I use Mobil 1 5w30 oil, and don't have a chip yet...
--Jeff
Old Mar 12, 2002 | 06:02 PM
litnfast's Avatar
If the exaust system is brand-new. It may just be temporary. My new Bassani smoked for a day.
Old Mar 12, 2002 | 06:08 PM
Boostin01L's Avatar
Hey JLightning,
How do you like your cutouts,what do they sound like?
Old Mar 12, 2002 | 07:04 PM
jackman's Avatar
A couple of months ago I took the L in for all the warranty work it needed (I/C, Clunk, etc. etc.). I mentioned that I had smoke on start up and VOILA, they replaced my valve seals no questions asked! Problem is history. Good part of that is they also replaced the head gaskets and had a good visual on the pistons and plugs. Turns out I also had a blown head gasket! Needless to say I was quite pleased with the feeling I just got a new top end exam and fix.... no charge. I had about 9000 miles on my 2000L when I took her in. Good Luck to you too!
Old Mar 12, 2002 | 07:32 PM
JLightning's Avatar
Boostin...it sounds mean as hell and have got plenty of complements so far Here's a pic...
Old Mar 12, 2002 | 07:35 PM
Boostin01L's Avatar
Looks good how much if you don't mind.Did you see any gains or just sound?
Old Mar 12, 2002 | 07:41 PM
JLightning's Avatar
it was $142 for the install of the magnaflow and the cutouts, but that included all mandrel bent stainless piping from almost all past the cats, a couple hangers and stuff, took em a little over 2 hous to do it because they had to fabricate the piping,but it ws well worth it I had them move the tips in and up a little when they made it...
Old Mar 12, 2002 | 07:43 PM
Boostin01L's Avatar
That's not bad looks good man.
Old Mar 12, 2002 | 07:50 PM
JLightning's Avatar
some more pics...
