Need TSB # for Pass Side head leak on 5.4 Lightning Motor
Old Mar 14, 2002 | 05:51 PM
Silver_2000's Avatar
Jake
youll start smelling oil burning on the pas sde cat after the truck sits for a while.. Mine never leaked enough to make a mess on the floor it was just stinking ....
Ill post more when i get it back from dealer Fri
Doug
Old Mar 14, 2002 | 06:02 PM
jakemarietta's Avatar
Thanks Silver
Be looking for your follow-up. Haven't smelled anything yet. Mobil 1 was down about 1/2 qwt in 3600Mi,
Truck only has 7800. No previous oil use from original oil or 1st change with conventional oil. Does these trucks use a little Mobil or maybe leak from header? Thanks again!
Old Mar 14, 2002 | 06:47 PM
David10n's Avatar
Hey Doug, I found it for the 1999 Lincoln Truck Navigator 2WD V8-330 5.4L SOHC VIN L SFI
http://www.alldata.com/TSB/77/997701DA.html
David
Old Mar 14, 2002 | 09:54 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
David10n,
Thanks for the info.
Looks like there are a couple other issues the L community is experiencing.
[list=1][*] TSB Number Issue Date TSB Title[*]01-12-2 JUN 01 Head Gasket - Right Hand Side Oil Leak[*] 01-4-7 MAR 01 Engine - Oil Recommendations/Applications [*] 00-26-1 DEC 00 Engine - Rough Idle/Noise When Cold [*] 00-20-1 OCT 00 Fuel Pump - Driveability Lack of Fuel Pressure[*]99-26-9 DEC 99 Fuel Economy-Customer Expectation vs. Vehicle Usage [/list=1]
Old Mar 14, 2002 | 10:17 PM
It doesnt look like the numbers match the Ford system.
But the dates and description might help them find them
Doug
