Transmission Lines
Old Mar 8, 2002 | 08:38 PM
DustOff49's Avatar
Question Transmission Lines
Does anyone know which Trans line is the exit and return from Cooler ?
Thanks,
Jon Lund
Old Mar 8, 2002 | 10:30 PM
Spike Engineering's Avatar
The ones connected to the cooler.
Old Mar 8, 2002 | 11:15 PM
fast1matt's Avatar
Exclamation Trans cooler line
When truck is cold start it & run it for 30 sec.Cut it off &
feel lines one will be hot so dont hold on to it,that is the
one comeing out of trans.Good luck
Matt
Old Mar 9, 2002 | 01:13 AM
NOSTROMO
Guest
Posts: n/a
I believe the line most forward of the tranny is the output. There is also a cooler bypass line on the transmission which only opens when the temp becomes high?
Factory tech we need you!?
Old Mar 9, 2002 | 09:36 AM
T Ellenberger's Avatar
You might have to crawl under to see it but, the lower line is the return to the trans.
Old Mar 9, 2002 | 11:03 PM
Factory_Tech's Avatar
The line at the rear of the transmission is the "in" side, the rear lube port, the one at the front is the converter out or the "out" port to the cooler. My admittiedly crude way of remembering it is the E4 takes it in the ***.
Hope this helps.
G
