Do I need an alignment??
Old Mar 6, 2002 | 12:13 AM
nikslightning's Avatar
Question Do I need an alignment??
I just did the bell tech 3/4 drop to my truck. All I did with the front was change the springs and put everything back together the way it was. The truck still drives pretty good with only a slight pull to the right. Should I go in and get an alignment just to be safe?
Nick
Old Mar 6, 2002 | 01:11 AM
speeder's Avatar
alignment
If it`s pulling to the right as you say then your truck is in need of an alignment. you should be able to take your hands off the steering wheel while applying the brakes and your truck should stop in a straight line.
Later.
Larry.
Old Mar 6, 2002 | 04:04 AM
krzcwby's Avatar
Definetly
You caster will be way off. Take a look, your tire will be pointing in at the top. This affects handling drastically.
Old Mar 6, 2002 | 09:52 AM
DHFerguson's Avatar
You'll need the cam bolts for the upper control arms installed before alignment.
Old Mar 6, 2002 | 11:35 AM
Silver01's Avatar
Yes, get an alignment. And as DHFerguson said, get the cam bolts. From what I understand, NAPA has them for a lot less than Ford sells them for. Also, if you don't already have these, get some of Herb's washers put on while you're at it.
Old Mar 6, 2002 | 11:53 AM
builtfordfast's Avatar
Here are alignment specs :
Lightning specs:
L.H. Caster: 6.9, +/- 1.0 Deg.
R.H. Caster: 7.4, +/- 1.0 Deg.
L.H. Camber: -0.5, +/- 0.7 Deg.
R.H. Camber: -0.5, +/- 0.7 Deg.
L.H. Toe: -0.05, +/- 0.15
R.H. Toe: -0.05, +/- 0.15
Lightning Owner preferred:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
Base F150: (tolerances same as above)
L.H. Caster: 6.2
R.H. Caster: 6.7
L.H. Camber: -0.3
R.H. Camber: -0.3
L.H. Toe: 0.03
R.H. Toe: 0.03
Ford Alignment spec:
Lightning Owner autocross preferred specs:
LH Camber -0.7
RH Camber -0.7
LH Toe OUT 0.05
RH Toe OUT 0.05
