"Hot Ticket" Ported and Polished Stock Throttle Body and Upper Plenum Intake
Old Mar 4, 2002 | 09:20 PM
WCFan's Avatar
Smile
In the old days much of what has been said is true (when carbs sat on intake manifolds). You do want to have good atomization of the air and fuel. What you also need to understand is that a textured surface is much like rocks in a stream. What do you find there eddy currents, rapids and white water no smooth laminar flow. Now if you wanted to generate more power you could pull the injectors and move them up stream in the airflow and have better atomization and also produce more torque. Location of the stock injectors was not done to create the most horsepower. There was a trade off between HP, emissions and packaging. Here is a question to ask yourself. Why do we now see plastic intake manifolds and throttle bodies? It is not just for the ease of manufacturing.
Old Mar 4, 2002 | 09:52 PM
Twisted99's Avatar
Nice explaination .....Now I think I understand.
So, what is the price with exchange ?
Old Mar 4, 2002 | 10:47 PM
TZrider's Avatar
Corner Carver
Extrude honing doesn't leave a mirror like polished finish,very smooth yes, but not polished...Granted we are talking very minor differences in power and flow( between the two finishes) but a difference none the less.. as for ported and polished heads. polishing does help in the exhaust port and many times in the combustion area ( domes) as it helps to prevent the accumulation of deposits which can cause " hot spots "leading to pre-ignition. and as some engine builders believe it also reflects heat back into the combustion chamber
Paul
Old Mar 4, 2002 | 10:52 PM
DL's Avatar
DL
Thumbs up
Hey TZrider,
Nice sig...
Old Mar 4, 2002 | 11:03 PM
WCFan's Avatar
Cool
Another reason for a smooth surface in the intake track is that it reduces the frictional heating that occurs. Look at some of the test results from Extrude-Hone. In the case of the Lightning a long smooth intake track can be conducive to temperature management.
Old Mar 4, 2002 | 11:08 PM
TZrider's Avatar
WCfan...Bingo...
Old Mar 4, 2002 | 11:19 PM
Silver_2000's Avatar
TZrider
Please refrain from outright marketing of products on F150Online.
Perhaps you or Metco should contact Steve about becoming a supporting vendor.
Doug
PS Nice Truck - Saw it in the show at Orlando
