boost dump pic ?
Old Mar 1, 2002 | 07:24 AM
SLICK0478's Avatar
boost dump pic ?
I want to know if ther is a pic of the plug-harness you have to disconnect to eliminate the boos dump. I also want to know will this give you a check engine light.
The truck really needs to have something done 1-2 shifts suck when it dumps,So any help would be nice from you guys. I am getting a chip soon so should I just leave well enough alone.
Also anyone else with a 2002 notice the crappy paint jobs from Factory, They convientelly forgot to paint the drivers door pillar by the lock mechanism it was barely painted I can see the factory primer-seal crap just thought I would let you guys know
sorry for the long post
Slick
Old Mar 1, 2002 | 07:37 AM
SLVRLTNG's Avatar
SLICK0478,
here is a pic I found. hope this helps you.....JR
https://www.f150online.com/forums/at...&postid=450928
Old Mar 1, 2002 | 02:58 PM
SLICK0478's Avatar
THANKS
Thank you
I unplugged it we will see how it goes on the way home from work tosay
Slick'
Old Mar 1, 2002 | 09:18 PM
soap's Avatar
Here ya go..............
--Joe
Old Mar 2, 2002 | 10:45 AM
KJ94GT's Avatar
So you unplug that and it holds boost longer? Anyone getting engine codes with it unplugged?
Old Mar 2, 2002 | 12:57 PM
soap's Avatar
It has nothing to do with holding boost longer. You unplug it so that it won't dump any boost. I've had mine unplugged since the day I bought mine and not a single warning light yet
Knocking on wood.........Joe
Old Mar 2, 2002 | 09:53 PM
PWR_WHLS's Avatar
Pardon my ignorance - I've read about this before, but really don't understand why our engines (or computer) would want to 'dump' the boost? - is it reading too much air or something..??
Thanks in Advance,
John
OHIO PLATES = "PWR_WHLS"
Old Mar 2, 2002 | 10:15 PM
4D THNDR's Avatar
Lightbulb
The only 2 reasons I've ever seen posted were the trans temp is too high or you bump the rev limiter. Either case will cause it to hold out boost for a few seconds. Had a lot of it when the chips first came out. Not much any more.
BTW, unplugging it will throw a code to the computer. If you're taking it in for service plug it back in and pull the battery ground for 15-20 minutes to clear the code.
