spring and shackle install help
Old Feb 22, 2002 | 06:21 AM
lihtning's Avatar
I'm about to try tackling the installation of my new front springs and my 2" belltech drop shackles. Anybody have the steps I should take, or any other tips I need to know. I've never tried this before and that's why I'm asking. Thanks for any help.
Old Feb 22, 2002 | 06:58 AM
nikslightning's Avatar
I second that notion......I purchased the 3/4 bell tech kit from this site and will try to install it today. Will I need any special tools? How long will this job take? Can it be done with just a 3 ton floor jack and some jack stands? Will I need the camber kit from napa? If so what part number is it? Any tips or tricks is appreciated....
Nick
Old Feb 22, 2002 | 07:12 AM
SLVRLTNG's Avatar
here's some tips and tricks, read Don's Bolt posts.....there are a few pics and suggestions from others as well. hope this helps....JR
https://www.f150online.com/forums/sh...5&pagenumber=1
Old Feb 22, 2002 | 09:30 AM
lightningbolt's Avatar
Silver-Bolt did my drop kit and I watched.
Floor jack and a couple jackstands and a ratchet, I think that was it. Floor jack the rear differential and block the front wheels.
Old Feb 22, 2002 | 01:00 PM
Ebbsnflows's Avatar
SLVRLTNG-
Thanks for posting that link...it was very helpful. I'm doing mine in a few days, that'll come in very handy.
Old Feb 22, 2002 | 01:13 PM
Ditto on the thanks! They will be very helpful...Now if I could just find some pitures like that for the back I would be set. Anyone have any pictures on a rear drop?
Nick
Old Feb 22, 2002 | 02:33 PM
clonetek's Avatar
to install the shackles:
jack up back of truck and place jackstands on axle tube
block front wheels.
using a floor jack, raise the body till there is no weight on the suspension.
i put the jack under the trailer hitch and jacked up there.
now you can remove the leaf spring/shackle bolts without them springing up and putting a dent in the bed. (and your hands)
it's been a long time since i did this.. maybe someone will chime in if i am wrong.
Old Feb 22, 2002 | 04:58 PM
Frank S's Avatar
Clonetek: Don't you mean put jack stands under the frame? If you put them under the axle tube, the leafs will go through the bed...OUCH! I just jacked it up from the hitch until the tires were 1/4" off the ground. Put jackstands under the frame in case the truck falls, it wont fall on you.
Old Feb 22, 2002 | 05:17 PM
SLVRLTNG's Avatar
block front wheels.
clonetek is right...stands under the axle tubes, jack up body to take weight off springs....it's a fairly easy install.....JR
