Installing an air/fuel ratio guage
I would have used the search function, but.....
anyhow, I just got my guages and I'm not really sure how to install the air/fuel guage. Any tips on the how to would be great.
Shane
Shane
you should just have to find a location that you want and then run power to the gauge something that goes on with ingnition switch then gotta run a wire from the gauge to the harness that goes to the o2 sensors they say the easiest won is the drivers side front 02 sensor
hope this helps
what gauges did you get i am waiting for autometer lunar series should be here anyday now
slick
hope this helps
slick
99-LTNG......make sure to tap into the black wire on the O2 sensor harness. That one is the signal wire. Oh and make sure you tap inot the front sensor no matter what. It doesn't matter driver side or passenger.......just whatever one is easier for you to do
--Joe
