K&n
Originally posted by cteselle
for 1999-2000: 33-2140
for 2001-2002: 33-2140-1
Johnie
There is no difference between the two. Either will work in any year truck.
While I did notice a bit better throttle response after putting in my K&N, dyno tests showed it only gained me 1rwhp. The inlet for the stock airbox can only flow so much air. To get the full benefit, you need to do more, such as open the bottom of the box.
when u say open the bottom of the box.. do u need to do those pipe things going out the front.. or can u just cut a space out and leave it like that...
Also what abou those ( i forget what they are called..) cone shaped filters made by i think K&N that have no box at all....how do those work with the L??
I cut a round hole in the bottom and used 3" tubing to suck in air from behind the lower bumper opening. Picked up almost 10rwhp by doing that. I've heard other people have had good results by just drilling holes in the bottom.
The filter kits work really nice, but are a lot more, around $200. I've got $60 into my setup. Check out these websites for info on those.
www.teamjdm.com
www.powersurgeperformance.net
www.lightningforceperformance.com
Bob
www.teamjdm.com
Bob
Wow! I just got my K&N filter last night, a little V-Day present for the L. I bought it from Summit Racing Catalog for 45.44 shipped. Ordered it on Sunday, here on Thursday. I cut the bottom of my air box, just half of it, and I noticed a little more of a whistle. Performance? I live here in Nebraska, roads are still wet and sandy....... But, it does seem to have a little bettrer throttle response.
Summit is the cheapest, I've checked!
Hope this helps!
Hope this helps!
