how to check & set your TPS voltage on a single bore throttle body.
#61
Originally posted by hooD
clonetek:
Your post really got me wondering about my 96 cougar 4.6L. The TPS was replaced when they rebuilt my tranny. Ever since then my engine idle has been on the rough side. Sometimes it will idle smoother, but more often than not it has a rough edge to it. Before the tranny was rebuilt (torque converter shot) the idle was so smooth, you would swear the engine was off!
Would the .99V apply to my cougar as well? I have not checked the voltage yet, but i plan on it after reading this post.
-hooD
clonetek:
-hooD
i dunno.. see if you can find the specs in a repair manual?
#64
Posting here because I think I have a TPS related problem...
5.4L S/C but should be typical. Stock throttle body.
Using a Predator, my readings are as follows:
1. Foot off gas... .97v, TP Mode = ?
2. Very light pressure... 1.0v or above, TP Mode = WOT
3. Foot to floor... 4.98v, TP Mode = P/T
Does that seem right? If "WOT" means wide open throttle, then I'm observing at all positions of the accelerator EXCEPT idle and foot to the floor! And I only get P/T when my foot is to the floor?
Unless "WOT" doesn't mean "Wide Open Throttle" and "P/T" doesn't mean part-throttle???
Can someone PLEASE check and see what you get???
THANKS
THANKS
#66
Yes.... but foot off the throttle = TP Mode "?", throttle to the floor equals TP Mode "P/T" and part throttle equals PT Mode "WOT"?
Maybe the Predator is confused? It can't be going off of anything but the TPS, right?
I'm headed out to run the EVAPDC route AGAIN in the hope of someday passing OBDII emmissions test so that I can get my "HEMI HA" license plate...
#69
Dan
#72
Need help with accufab TB
I put a accufab single blade TB on my 04 L and with the TPS set to .99 , the idle is too high. changing the set screw doesnt do anything. if u tap the idle, it will rev to 1100 rpms for about 5 secs and then goes back down. shifts diferently and not as hard. put the stck one back on and the truck runs fine. can anyone help or anyone had the same problem.
#73
When I installed an Accufab SBTB on my 01L in 2002, when I let off the throttle, it would hang up at about 1100-1200rpm - then drift down to about 700-750rpm. I bent the throttle return spring bracket back a bit to increase the tension on the throttle return spring - has been fine ever since. My TPS was about .96v - adjusted to about .99v - didn't make any difference.
#74
