Speedometer Calibrator
Old Feb 11, 2002 | 06:50 PM
nostreetracing's Avatar
I know Dallas Mustangs sell a device called SpeedCalc for the late model mustangs to recalibrate your speedometer after gear and or tire changes. Does anyone know of something like this for the Lightning? Thanks for your help.
Old Feb 11, 2002 | 07:32 PM
GoDogGo's Avatar
nostreetracing,
Sure, any of the VSS speed recalibrators will work in a Lightning or an F150 for that matter. However, if your vehicle is a 2001 or a 2002, the recalibrator will work, but at cruise, the torque converter will not lock up resulting in higher tranny temps and lowered gas milage. I know this because I did a gear swap in my 2001 4x4 F150. Turns out the hardest part of the whole swap was the speedometer recalibration. I did get one of the recalibrators, works great around town, but I have had to learn how to drive at cruise to keep the TQ engaged.
Chris S.
Old Feb 11, 2002 | 07:57 PM
captainoblivious's Avatar
whatever happened to the old days of just changing a little gear after you do a simple math equation?
Old Feb 11, 2002 | 08:07 PM
RDY2RAC's Avatar
if i'm not mistaking your tuner can accomindate for tire and gear changes in the chips proggramming
Old Feb 11, 2002 | 08:11 PM
LIGHTNINROD's Avatar
Yep, he can my chip takes into account the 'smaller' M/Ts that I run at the track.
Dan
Old Feb 11, 2002 | 08:19 PM
Well, I was wanting to do it without going to a chip at this time. I only have 520 miles on my L and was going to wait a little longer for a chip. Guess I could just wait on all changes and get a chip burn at the same time. Thanks to all for the help.
Old Feb 11, 2002 | 08:23 PM
Lightning Boy's Avatar
I know Sal can accomindate for gear and tire changes. But im not sure if JL or Jim can. Contact your tuner and find out.
Old Feb 11, 2002 | 08:31 PM
GoDogGo's Avatar
Thats interesting.
I was specifically told that on the 2001 Ford computers they were not yet reprogrammable via a chip for tire or gear swaps. Something to do with a single bank set-up on the 2000's and earlier versus a dual bank set-up for the 2001's - all in preparation for a general industry standardization for computer controls that will roll in in the next couple of years, as I understand.
Now, this was for a supercrew, and its computer architecture may be different from the L's. Apparently that is the case. Either that or the aftermarket has caught up.
Chris S.
Old Feb 11, 2002 | 08:37 PM
GoDogGo's Avatar
I remember more to this now. I was told, on the 2001's, that if you switch gears or tires to an existing size offered by Ford, say a gear swap from 3.55 to 3.73, that it was possible to reprogram via a star tester, or chip. But, if you went from 3.55 to 4.10 like I did, you are SOL, since Ford doesn't offer 4.10 as one of their gear choices.
Anyone know better?
Chris S.
Old Feb 11, 2002 | 10:47 PM
99REDBOLT's Avatar
Thumbs up
if you decide to get the chip reprogrammed you might have to send it back and forth a few times to get it perfect for your combo. it has taken me a few times but now it is perfect.
