oil Level problem
Old Feb 10, 2002 | 08:27 PM
frank2's Avatar
Angry oil Level problem
Changed oil today with 4500 miles on it. truck has 5200 on it. when I put used oil into milk jug I barely filled it(4QUARTS) So I was almost 2 quarts low on 4500 miles!!! My 2000 never used oil like that or is i because I have increased the boost on this one(4# pulley) all help would be appreciated,Just switched to Amsoil XL-7500 full synthetic and now we will see what happens
Old Feb 10, 2002 | 08:33 PM
L in Detroit's Avatar
ive seen a couple post about this for 2001's and it is normal read that it lessens out at 10K, but no personal experiance myself, i also have a 2000.
jim
Old Feb 10, 2002 | 09:41 PM
Kerrdogg's Avatar
My 01 was using a quart every 500 - 600 miles and smoked on startup. Three cylinders had oil fouled plugs upon inspection, though compression and leakdown tests suggested motor was fine. Engine replaced under warranty last week, 400 miles so far with no smoke or oil use. Keep an eye on it.
Old Feb 11, 2002 | 01:21 AM
Skank Dog's Avatar
frank2- My 01 has 4400 miles and it was also 2 quarts low!! It didnt even register on the dipstick! A friend of mine also has an 01 and his has around 8000 miles and his was 3 quarts low on his last oil change! I dont know what is going on, but Im sure others are doing this and people just havent noticed it yet. My 01 is modded like yours, but my friends was bone stock!!! So mods are not the problem. Mine does smoke sometimes at startup, but not always. Im gonna keep am eye on my oil level every 1000 miles.
Old Feb 11, 2002 | 07:51 AM
LIGHTNINROD's Avatar
20,300 miles with no measureable oil useage. Maybe your oil is being forced up into the intake area by an overpressurized crankcase. Pull the boot off of the th/body and see if oil is draining by the th. blade/blades.
Dan
Old Feb 11, 2002 | 06:46 PM
frank2's Avatar
I did just install the ford racing breather cap so maybe that will take care of some of the problem.................I hope!!!
Old Feb 11, 2002 | 06:47 PM
frank2's Avatar
Kerrdogg,
what was the final reason why they replaced your motor!!!!!
