Knocking noise. Need Advise
Old Feb 4, 2002 | 01:08 PM
11secL's Avatar
I am getting a knocking noise from my #7 cyl. It started about 48 hours ago and has progressivly gotten louder. Its still not that loud, but since it has gotten worse, I would like to have it fixed before something worse comes out of it. About a month and a half ago, I had my chip reburned for my 4.10 gears. I don't know if the chip is the problem or not. What do you suggest?
Old Feb 4, 2002 | 01:38 PM
DB's Avatar
DB
Not a good sign. Hopefully it's not a rod preparing to make its way into the outside world.
If it were me I would remove what mods I could and make an appointment with the dealer.
Old Feb 4, 2002 | 01:41 PM
11secL's Avatar
I just ordered some new plugs--NGK's and I will call my tuner to see if the chip needs a reburn. I seriously hope this solves the problem!!! The L will stay parked for now. Sound like a good starting point??
Old Feb 4, 2002 | 01:43 PM
DB's Avatar
DB
Not a bad idea to park it. If those new plugs don't cure the knock, then take it in right away.
Might want to make an appointment first in case something blows before you can get it to the dealer though.
Old Feb 4, 2002 | 04:00 PM
11secL's Avatar
Thanks DB.
Has anyone else had this problem???
Old Feb 4, 2002 | 04:07 PM
easterisland's Avatar
Is the spark plug loose?
Old Feb 4, 2002 | 04:41 PM
Skank Dog's Avatar
Im with easterisland, check that plug to make sure its tight! If its loose, tighten it and it will solve the problem. If the plug is tight, I wouldnt drive it period!! Have a tow truck come get it! If it is the rod it may decide to una$$ your engine on the way to the dealership, then your screwed altogether! Better safe than sorry.
Old Feb 4, 2002 | 04:51 PM
2_FAST4U's Avatar
I am with everyone on the plug idea!!!
Oh.....and don't dog it!!!!!!!
Old Feb 4, 2002 | 04:58 PM
11secL's Avatar
I checked that sucker last night and she was pretty tight. I am wandering and hoping that it is just time for a replacement.
Old Feb 4, 2002 | 05:05 PM
ICULOKN's Avatar
When you checked it did you pull it out? It may be burnt off and caused a bent or burnt valve. That can make a tapping or knocking sound....
