Diablo Chip and 3#Pulley
Old Feb 4, 2002 | 12:05 AM
14U2C's Avatar
I have an 01 L and am getting paranoid from all the thread about the problems with them blowing up. I have 8K miles and have a Diablo chip with a 3# pulley and an airkit. I am running stock plugs and have seen that maybe I should change them. If I get rid of the chip and just run the pulley, and airkit, do I still need to do the plugs? My truck seemed faster light to light stock. Out of the hole, I could mash on the gas and it would just hook up and go! With all these mods it just seems to shift hard and burn rubber! What do you guys think?
-bm
Old Feb 4, 2002 | 12:23 AM
KGM's Avatar
KGM
Wink Rods Might Be A Good Idea Too
Change the plugs, buy some Nitto's.
Old Feb 4, 2002 | 12:31 AM
BLackBoLT99's Avatar
Suspended For Rules Violations
Re: Diablo Chip and 3#Pulley
I hope by getting rid of the chip you mean just buying a different one! The problem with engines blowing up is not taking care of the truck the way it should be.... change the plugs to a colder one(NGK: TR5's or TR6's, Denso's: IT16's or IT20's[whatever floats your boat!]), I think everyone is agreed that the stockers suck. And it doesn't matter WHO'S chip you have(dispite what people say!), just as long as it's programed right! Listen for detonation, check your plugs reguarly and don't abuse the truck, and I don't see any problems coming in your future. Just MY opinion!
Old Feb 4, 2002 | 12:33 AM
red gen 1 94's Avatar
For goodness sake......Change the plugs.....its the single most inexpensive insurance you can buy for your engine........Make darn sure the plugs are tight.....go back now and again to check the tightness of the plugs............Keith
Btw.......change the plugs and keep the pulley.......and the chip!!!
Old Feb 4, 2002 | 03:46 AM
ICULOKN's Avatar
-bm
If you just run the pulley & airkit with stock plugs and no chip you wish blow if up for sure. All you need is a good set of plugs with that combo...
Old Feb 4, 2002 | 08:47 AM
LIGHTNINROD's Avatar
14u2c:
I don't think you are thinking 'straight'. With the combonation you have(and your fear) you should drop the pulley not the chip. If you run with a pulley and air filter kit you have increased the boost--with no chip, you will be running way too lean.
Dan
Old Feb 4, 2002 | 09:02 AM
bubbalightning's Avatar
Re: Re: Diablo Chip and 3#Pulley
Old Feb 4, 2002 | 11:39 AM
ICULOKN's Avatar
Re: Re: Re: Diablo Chip and 3#Pulley
Originally posted by bubbalightning
The stock plugs are fine. They of themselves will not cause engine problems. If you are running too lean they might cause problems.
Too much power will make these things break!
Ok, Here is a friendly reply to this....
I agree, too much power can make these things break. Now what is to much power? Who really knows? I have talked to many motor guys that say STOCK they should handle close to 18-20 PSI with everything working right. Are they right? We have seen motors let loose at 10-16psi. I guess some are better than others.
Now stock plugs not being a problem?? THATS BULLSH$$!!! With any NOS system you are suppose to run cooler plugs, with any BLOWER your doing the same thing as NOS and you are suppose to run a cooler plug with Higher Boost as well. A plug can cause, Bent Valves, Burnt Valves, Holes in Valves, Burnt or Holes in Pistons, and the biggest thing it could do is break a rod. Ever heard of a Liquid locked motor? Something similar could happen. A piece of a plug that falls onto a cyl. wall could easily lock a piston up long enough to make the LONG stroke of our motors BREAK a rod. It does not take much to for things like this to happen. Based on some of the pics of plugs that have been posted, there have been some good pieces of metal going down in these motors. Just my little thoughts......
Old Feb 4, 2002 | 12:02 PM
Re: Re: Re: Re: Diablo Chip and 3#Pulley
