92mm maf
Old Feb 3, 2002 | 10:56 AM
Don's Bolt's Avatar
I found this the other day I don't know anything about it, but the tube looks interesting.
http://www.andersonfordmotorsport.co...ew_frames.html
Old Feb 3, 2002 | 11:10 AM
HIGH ROLLER's Avatar
Anderson only has that available for the 80mm size,within a month they told me it would be available for our 90mm if anyone was interested.
Old Feb 3, 2002 | 11:22 AM
JeffsLightning's Avatar
You think we would need a chip reburn for that pipe? Looks like Santa is coming early....lol
Old Feb 3, 2002 | 11:28 AM
jackman's Avatar
Correct me if I'm wrong but every air tube I've seen to date is undersized. These tubes should be 4" in dia. minimum. Anything less and you're making restriction! Don't get me wrong, they are pretty, but this tube also appears to be undersized, in my humble opinion.
Old Feb 3, 2002 | 11:31 AM
Marc Arnold's Avatar
Hi Folks. I'd like to introduce myself to the list. My name is Marc Arnold
Marc, F150Online had Vendor rules that prevent this type of blatant advertising. See this link for details.https://www.f150online.com/forums/an...?s=&forumid=50
If you are interested in becoming a suipporting vendor send me an email. Silver_2000@svtlightnings.com . If Not do not post marketing or contact info on these forums. Thanks in advance.
POST significantly edited by Moderator
Thanks in advance
Doug
Old Feb 3, 2002 | 11:35 AM
Marc welcome, what is the diameter of the powerpipe? Will there be a larger pipe in the future like High Roller stated? I'm interested..... Jeff
Old Feb 3, 2002 | 11:40 AM
Power Pipe Sizing
Just FYI, I didn't state this earlier, but the AFM Power Pipe starts 5" at the TB and necks down to 4" at the MAF. Several sizes were tried and this turned out the best for packaging with no restrictions.
Old Feb 3, 2002 | 11:52 AM
Marc,
Do you have a graph of the air-fuel you can show or tell me how much this 92mm might have changed the air-fuel?
Matt
Old Feb 3, 2002 | 12:20 PM
air/fuel
Matt and others,
I do not have the A/F graph but will ask to have the file sent and will then post. Should not be a problem but may take a day or so.
Old Feb 3, 2002 | 12:32 PM
Marc,
Looking forward to the air-fuel file. Also can you tell me will the AF-01707C power pipe for our stock 90mm work with our stock airbox or does it require a open filter?
Old Feb 3, 2002 | 12:38 PM
Another good question. Should have put more info up on the site. Will find out and let you know. I suspect it will not, but will find out.
Old Feb 3, 2002 | 12:44 PM
Re: Power Pipe Sizing
4" is 101.6 mm. Are the kits ready now for shippment? thanks Jeff
Old Feb 3, 2002 | 08:40 PM
Matt,
Just spoke with Rick Anderson and here is the info... The stock MAF Air-Fuel ratio was 11.9-12.1. The Pro-M 92mm Air-Fuel ratio was 12.0-12.2. This is good, as it gives the test validity, i.e., a good test of a component change, not a tune.
The stock air box will not work with the Power Pipe, sorry. That's why the Power Stack is included in the kits.
Hope this helps.
Old Feb 3, 2002 | 08:46 PM
Marc,
Thanks for the info and i have one more question,when Rick was dynoing both meters was there a chip in the truck or was that off the stock computer to arrive at those air-fuel numbers?
Matt
Old Feb 3, 2002 | 09:14 PM
Stock computer, Matt.
