Do I need a reburn?
Old Feb 1, 2002 | 06:56 PM
cherring's Avatar
Question Do I need a reburn?
Just picked up a "used" flipchip from a fellow lightning enthusiast here in the Dallas area, and have a quick question-
The code matches my L, however, he had it custom burned- he had a 90mm AF, and a 2 lb pully installed. My question would be, do I need to worry about reburning it to stock (although I will probably get the 90mm at some point) or will it not make that much of a difference?
I'm gripping to get it in, but don't want to do it if I won't see the improvement, or possibly screw something up-
TIA!
Chris
Old Feb 1, 2002 | 07:37 PM
RhinoSlug's Avatar
I would personally make a call to whatever tuner supplied the chip originally!
Old Feb 1, 2002 | 07:41 PM
cherring's Avatar
Thx Rhinoslug-
Yes, I figured that would be the brightest thing to do- but was looking for an answer after hours (too late to call now) so I'd know if I could put it in tomorrow-
Hmmmm. I'll see what I can dig up.
C.
Old Feb 1, 2002 | 08:28 PM
Lightning Boy's Avatar
You will need to get it reburned.
Old Feb 1, 2002 | 10:04 PM
usahooters's Avatar
I agree you will have to get a reburn.
Old Feb 2, 2002 | 08:41 AM
cherring's Avatar
Thx guys-
I have the 90mm on it's way, so I guess technically, I have two choices- either get it reburned, or match the program- and pick up a 2#-
*Sigh*...guess I'll have to get the 2# now...
C.
Old Feb 2, 2002 | 08:44 AM
cherring's Avatar
Ah, one quick thing- just in case the boss won't let me rush out and get the 2#, who's the "preferred" vendor for the reburn?
TIA
Old Feb 2, 2002 | 09:18 AM
awhittle's Avatar
What brand chip is it? The tuners can only tune the brand chip that they own software for.
Give us the brand...and we can give you the choices.
The 2# pulley may not be an issue but the fuel that you can get and the 90 mm vs stock definently is.
Andy
Old Feb 2, 2002 | 03:27 PM
cherring's Avatar
Duh. Sorry guys-
It's a Superchips Flipchip.
TIA.
Chris
Old Feb 2, 2002 | 03:45 PM
usahooters's Avatar
If you get your 90mm MAS installed you should be ok. Running a stock pulley shouldn't hurt a thing. If I we're to buy a pulley I would go with a 3# or larger lower and leave that upper alone. I changed my lower by myself in about 30 minutes and its easy to go back to stock if I need to.
Old Feb 2, 2002 | 03:54 PM
cherring's Avatar
Thx, USAHooters-
The 90mm's on it's way, so I guess I'll give it a shot and see what happens-
Appreciate it!
C.
