what should tire pressure be?
Old Feb 1, 2002 | 12:26 PM
hugo blk lytn's Avatar
i have the stock wheels and i'm noticing that my tires are wearing out unevenly. what should the pressure be in them?
thanks
Old Feb 1, 2002 | 12:31 PM
LIGHTNINROD's Avatar
I believe the owner's manual say's 32 psi--front and rear.
Dan
Old Feb 1, 2002 | 04:24 PM
usahooters's Avatar
I had the same problem, with such a wide tire they want to wear the corners off. I went to 40psi and it has really helped even though it does give you a stiffer ride. When I go to the track I run 28 psi in the rear. Its on the tires Max of 44 psi.
Old Feb 1, 2002 | 04:34 PM
11secL's Avatar
I ran about 40psi and the center of the tires were bald in a month. I would stick with the suggested 32psi, 34psi at most. Mine have held up fine with that.
Old Feb 1, 2002 | 04:37 PM
usahooters's Avatar
WOW in a month. I've been running it in mine for nearly 6 months and they look great. Must have been the foot thing.
