Running both bright/dim elements at once works great!
Old Jan 28, 2002 | 04:32 AM
Bill Voyles's Avatar
Some of you expressed a keen interest in my experiment to operate both the bright and dim elements at once when my brights are turned on. It puts about twice the light on the road.
I told you I would keep you abreast of my experiment. So far, it is working just fine, even with 100/80 watt Hella (Germany) Clear Bulbs. They are 35/25% brigher than OEM bulbs.
One dim element did quit a while back and I replaced the bulb with a new one. It's been about two weeks since then and the other bulb has about 45 days on it now. So, that could have been just a fluke. I enjoy the extra light so much that I want to continue the test even if I did burn out one element.
You can test this yourself by simply pulling back on your bright/dim switch. Hold back on it for a while to see how much brighter the road is right in front of your truck. It's impressive.
As time goes forward, I'll try to keep you informed.
BillVoyles
RedLowRyder
Old Jan 28, 2002 | 08:06 AM
LIGHTNINROD's Avatar
Thanks Bill...........
I need all the illumination I can get! How do you do this?
Dan
