foglight mod :)
Old Jan 23, 2002 | 03:18 PM
whitetoast11's Avatar
foglight mod :)
Well done,,, replaced the use of a small file with a 35,000 rpm dremel tool and the job took 10 minutes Great directions svtlightnings.com
Now i can turn on my foglights whenever i want to haha
~Toast
Old Jan 23, 2002 | 03:23 PM
AggieSVT's Avatar
Toast,
Did you have to take your switch apart or did you work through the holes. I looked at mine and I don't think there is anyway I can do it unless I do take the switch assembly apart. The holes are just too small and not in the right place.
Aggie
Old Jan 23, 2002 | 03:27 PM
i just took the assembly apart by cutting the tops of the heat tabs off. To put it back together all i did was use a glue gun and and place a drop where you should still see the heat tabs on top of each one. End result is an assembly which looks exactly like the original assembly, with the same way to take it off again should you ever need to.
~Toast
Old Jan 23, 2002 | 03:31 PM
AggieSVT's Avatar
Excellent idea Toast.... I hadn't thought of that one. That is what I will do. I was already to do the mod, had the directions from svtlightnings.com, but I really didn't want to take the switch apart. I know I will probably never be in there again, but I also did not want to permanently seal it up again.
Thanks!
Old Jan 23, 2002 | 03:37 PM
No problem, i can't say how much i love my dremmel tool, it fits into so many places. Without it it would take a long time to file down, if you or anyone else doesn't have one i'd suggest using an exacto knife or something along those lines.
Have fun with your mod. Me, i can't wait till its dark so i can play around with it
Old Jan 23, 2002 | 03:39 PM
svt360's Avatar
hey guys,will that mod enable the driving lights to work with the auto lamps??
Old Jan 23, 2002 | 03:42 PM
AggieSVT's Avatar
Got the dremel, and I also love that thing. I have used it for a lot of small jobs (including the keypad mod). I think it will make the job a lot faster, and a lot cleaner if I take my time with the grinding.
Old Jan 23, 2002 | 03:45 PM
AggieSVT's Avatar
According to the directions at svtlightnings.com, and by looking at the mechanism, you can have it where the lights come on anytime. You just need to follow the directions on what to do and once you see the mechanism, it will all make sense.
Sorry toast if you already responded! You have done the mod, I have not yet, I have only researched and looked at the assembly.
Old Jan 23, 2002 | 03:49 PM
Madhouse's Avatar
Toast -
Can you post a pic from the front of your truck with the fogs on, headlamps off? I can't get a good mental picture of how this would look...
Old Jan 23, 2002 | 03:52 PM
svt360's Avatar
got the sig thing,
Old Jan 23, 2002 | 03:57 PM
WHAT04's Avatar
As one of the official writers of instructions on that web page, I can answer a few questions, although its been a while since I did the mod. Actually took the switch out of my '00 and put it in my '01.
The second ramp that I cut only allows the switch to be pulled out in the autolamp position. When it is pulled out in the autolamp position, my fogs are then always on. I believe this is an anomoly with DRL on Canadian L's.
To do the job properly, the faceplate should be pulled off as per the above instructions. Also, it really makes a difference if you cut the detent groove further around the shaft if you want the factory feeling "click" when you pull the switch out.
Old Jan 23, 2002 | 06:01 PM
no problem to post pics,,, the L is dirty so don't mind that,, its raining and rain in the winter around here sucks cause salt just piles up on the truck
And yeah, it works great when you have auto lamps on,, makes it so you can run autolamps with the fogs on, or off
~Toast
Old Jan 23, 2002 | 06:10 PM
rubbermann's Avatar
Auto-Lamps work great with it. The only problem is that you fogs dont turn off when you switch your beams to high. But other then that it works great.
Old Jan 23, 2002 | 06:49 PM
thepawn's Avatar
If I remember right, only 99's needed wiring done to run it with autolamps or in park. 2000+ had a different switch mechanism/harness and worked fine.
Daniel
Old Jan 23, 2002 | 06:52 PM
soap's Avatar
I had to splice 2 wires together in my 2001.
--Joe
