How do I remove corner lenses from 2002 F150
Old Jan 18, 2002 | 07:37 PM
MarkY's Avatar
I'm trying to install the clear corners that I purchased. Can someone tell me how to get the stock corners out. I lifted up one of the black levers that holds the headlight assembly in, but the second black lever won't budge. I also removed the "star headed" screw from the corner lens.
Any help on this is appreciated. The truck is a 2002 F150 Supercab.
Old Jan 18, 2002 | 08:12 PM
Silver_2000's Avatar
If the 2002 is like the 2000 then all you have to do is remove one torx screw and slide the corner straight out. It slides on arail like system straight out
There are a couple pictures here in the Lighted Logo How To from My site.
http://www.svtlightnings.com/svt/lig.../logogrill.htm
Doug
PS SVTLightnings.com and F150Online.com are going to be mentioned in an upcoming issue of MM&FF magazine so get your subscriptions renewed !!
Old Jan 18, 2002 | 08:42 PM
MarkY's Avatar
Thanks Doug, I got them installed.
Old Jan 18, 2002 | 09:27 PM
whitetoast11's Avatar
arghhh,, i just did that mod as well, passenget side went in with ease, but driver side seemed to have to be jammed on, as if the corner lens i got was misshaped somehow.. Anyways, looks good for now,,, although the bulb seems to fit in the new clear lense very loosly compared to the factory set,,,, is this normal??
