160 degree thermostat 'scientific' info....
Old Jan 17, 2002 | 11:14 PM
DL's Avatar
DL
Talking
They want to start using them, In a very good way..
Old Jan 17, 2002 | 11:21 PM
Twisted99's Avatar
I spoke with Sal before adding the 3# pulley and stated I had concerns about detonation. I asked if the 160 stat would help. He seemed to think it would. Not wanting to speak for him but I recall a positive attitude. He does not sell them. I think maybe more research may be needed. I would accept the dyno numbers posted as good enough for me. To blame a thermostat for a slight loss of et seems well ,disputable. NO flames intended.
If a cold engine out performs a hot engine.......What is the question here?
Old Jan 17, 2002 | 11:31 PM
ICULOKN's Avatar
Twisted,
Right on the money, You ICE down your motor at the track, You wait & wait for that puppy to be cold. I cant see a 160 stat makeing you loose power unless it makes it to cold for the plugs. Which a 160 really is arond 168 or 170 operating temp. Should not be nearly to cold at all!!!
Whoever yanks their 160 out, sent it to me!!! save me $25!!!
Old Jan 18, 2002 | 02:17 AM
HANKFAN's Avatar
Peter B
HIGHROLLER posted his dyno results not to long ago and he gained 8hp by changing from the factory thermostat to the 160 degree theromstat. So I can't imagine why you would lose .17 at the track from changing the thermostat!
Old Jan 18, 2002 | 08:18 AM
HIGH ROLLER's Avatar
Cool Dynoed all 3 stats
Yes i have dynoed all 3 thermostats on the same day and from going to the 160 stat made a noticeable difference of 4HP and 7 pounds of torque more than the 170 stat and lowered my air-fuel down a little lower also! My stat will stay in my truck!
Matt
Old Jan 18, 2002 | 08:41 AM
jarmstro's Avatar
Post
Originally posted by ICULOKN
Twisted,
No.... you ice down the intake not the motor, of course water drips all over the motor then.
This allows for a cooler air charge.
