Towing
Old Jan 15, 2002 | 05:48 PM
Sleeper's Avatar
Towing
I have read prior posts on towing doing a search but I want to cast out a question.
I have bought a race car and trailer as a package deal. Trailer is a 24 foot Pace enclosed--new ones spec out at 3500 lbs with a 350lb tongue weight. Tongue weight is probably my biggest concern. I am hoping the old ones weighed less since they had less features on and in them. Car that will go in it is about 2400 lbs with 50/50 weight distribution on the wheels. It is a tandem axled trailer and I have installed trailer brake control in my Lightning for the electric brakes. Anybody towed with a similar configuration? My main dilemna is if I will need a load distribution hitch.
Old Jan 15, 2002 | 06:19 PM
Jimb's Avatar
IMO, you should get a WDH.
Ideally, tongue weight should be 10% of the trailer weight. Your empty trailer is nicely balanced.
You might get away without the WDH, depending on how the car is loaded, but why risk it.
Old Jan 15, 2002 | 10:30 PM
SVT Bob's Avatar
Sleeper, I tow a 25ft travel trailer. The tongue weight is about 425 pounds. On rough roads I did bottom out. I have just put on a set of Air Lift air bags. Also keep in mind these F1 tires cannot handle a lot of weght. The sidewalls are very thin and have known to blow. I got 16 inch steel wheels and tires just for towing. Bob.
Old Jan 18, 2002 | 03:16 PM
Sleeper's Avatar
Thanks guys, will probably put WDH on it next week. Still waiting for prior owner to fully unload it. I will advise on how it goes with and without the new hitch set up.
