4lb pulley and stock plugs
i'm going to be putting in a jdm 4lb pulley in the next few weeks. Anyway i was woundering if it will be alright to run with stock plugs for a few months, until i get around (the money) to buy a set of oem plugs. I usually don't run my truck to hard and i don't go to the track (yet)
DAvid
DAvid
Probleminfected,
Believe me, I went through the same delima several weeks ago as I plan on addin a JDM 4# lower too (tomorrow!!). I decided to play it safe and install cooler plugs. I just changed them about an hour ago. Really, it wasn't that bad changing the plugs and turned out to be easier than I thought it would be. Decided on Denso. If it were my truck, I would change them and take no chances, my 0.02.
GDG
GDG
SPEND THE $15 BUCKS TO GET COLDER PLUGS!!!!!
There is a guy in phx (I wont say any nAmes to protect the innocent) that posts on here. Installed the 4#, 1 week later his truck engine is blown apart. All because he didnt install the plugs, so do it!
What happened to this guys engine? Did a rod/rods break or did he run too lean and burn up his plugs and pistons and valves?
I'm really trying to understand what causes these engines to blow. It sounds like most of it is broken rods. Not people running lean and detonating and other things.
Bubbalightning ran stock plugs with a 4# lower and metco upper. His engine blew up only because his rod broke. He said there was no other damage.
I have been running my new 3# since the 26th of December with stock plugs........keeping in mind that i had only maxed it out like twice and it was for a few seconds...........Im with everyone else.......i changed my plugs last night (NGK TR6's.) and as easy as it was i would be stopping by my local Advance Auto to pick me up a set............Hell for $14.00 its the best insurance you could possibly get....................
