smoke on start up
Old Jan 11, 2002 | 11:06 AM
Whit01Lightning's Avatar
smoke on start up
hey...my friend has an 01 "L" (silver)
we got them the same day. they both have similar miles.
about 3000. anyway, his has begun to let a puff a white smoke out on start up. any ideas?
Old Jan 11, 2002 | 11:17 AM
99svtlightning's Avatar
Most L's do. My 99 did and my 01 did it new with under 100 miles.
Old Jan 11, 2002 | 05:05 PM
frank2's Avatar
Mine does too, I think they run them richer to protect the motor from leaning out
Old Jan 11, 2002 | 05:37 PM
LIGHTNINROD's Avatar
Have him remove the intake boot where it clamps to the throttle body. Expect to see oil in the t/b, boot, and plenum behind the th/ body--it may even be 'draining' out of the th/body. I think this unwanted oil is the cause of much of the 'smoke' we see on start-up. Don't think it hurts anything but it may dilute the air/fuel charge?
Danl
Old Jan 11, 2002 | 05:43 PM
redlite's Avatar
Got a 99' with about 19000 miles. Had about 20 epidodes of blue, oily smelling exhaust smoke on cold start-up in cool/cold weather in a 28 month period. These are the ones I saw.
No big deal. I doubt if it hurts anything. In fact, I have not seen it for quite a while.
Old Jan 12, 2002 | 09:24 AM
jackman's Avatar
Hey guys, took the L in for the i/c fix and told them I was getting some smoke on start up. No problem, they replaced my valve seals without batting an eye! That was very cool because when they pulled the heads they found head gasket leaks from #2 & #4 cyl. toward they outside of the motor! So if you have a respectable dealer you may want to run that one by him.
Old Jan 12, 2002 | 07:03 PM
Kerrdogg's Avatar
Jackman,
How many miles were on your L when this took place?
My L has had a bad smoking problem on startup since day one and Ford has authorized a replacement engine for it but I am aprehensive. My start up smoke is very bad if the truck idles at all before shut down and is pretty much a clear case of leaking / missing valve seals. Upon inspection of my spark plugs at 2000 miles 3 cylinders had oil foulded plugs and oil consumtion is around a quart per 600 miles now. I'll try to post a pic later of old "Smokey" doing her thing during a recent startup after a 3 minute idle and 2 hour cool down, it isn't pretty.
John
01 L
Old Jan 12, 2002 | 07:13 PM
Kerrdogg's Avatar
There she blows!
John
01 L
Old Jan 22, 2002 | 02:03 PM
Whit01Lightnin's Avatar
come to think of it, my truck smokes all the time! and it isnt from the tires! well, they ARE 33" super swampers
