Help!!!!
Old Jan 5, 2002 | 02:05 AM
rfat16's Avatar
Help!!!!
Can anyone give me some advice????? I'm trying to put on my lower pulley and i can't break it loose(the Nut or whatever it is holding on the pulley) can anyone give me a tip on breaking it loose??????? ASAP.
Old Jan 5, 2002 | 02:12 AM
ICULOKN's Avatar
You have to have a 1/2 breaker bar. You may even need to hit it a few times with a hammer. Many have broke bars trying to get it off. If I remember right it is reverse thread I think? Double check that!!! Put some elbow grease behind it man!!
Old Jan 5, 2002 | 02:16 AM
rfat16's Avatar
I have a 1/2 and a hammer that i have just pounded the bar i was wondering if there was some catch. Thanks for the quick reply. I'll be back in a few after i go try again to see if there are any other tips
Old Jan 5, 2002 | 02:25 AM
rfat16's Avatar
Just got it off.....thanks iculokn i know i sound kinda dumb but do i need that 3 pronged piece thats attached to the stock pulley??? if so how do i get it off????
Old Jan 5, 2002 | 02:26 AM
ICULOKN's Avatar
Just check the directions to make sure your hitting it in the right direction. I cant remember, my instructions are out in the garage and I cant climb in the cast buddy or I would go get them!! Hit the SHI$$ out of it!!!
Old Jan 5, 2002 | 03:22 AM
rfat16's Avatar
ICULOKN i gotthat all done. Thank you but i do have one more question. I'm putting in an air intake system and it came with no instructions. It is a JL system. It came with 2 conector pieces one looks like it will fit but the other doesn't look right for anything. There is also some sensor of some sort right in the middle of the stock intake system. What is it? and do you take all of the stock intake system off.
Old Jan 5, 2002 | 09:31 AM
JohnnyLightning's Avatar
rfat: give me a call i can fax you instructions or e-mail them to you......JL
Old Jan 5, 2002 | 10:53 AM
ICULOKN's Avatar
RFRat16,
Get JL to fax/mail you the instructions if you havent figured it out by now, sorry i wetn to bed. You do replace most of the parts up to the stock rubber boot. Some of the stock parts are reused.
Have you figured it out?
Old Jan 5, 2002 | 11:01 AM
walker887's Avatar
there are 2 nuts and 1 bolt holding the cage on , with JL instructions remove the bolt and 2 nuts, cage will follow. reinstall the 2 nuts and leave bolt out, put it with old parts, the remove 3 bolts holding flange inside of balancer. install new pulley with the 3 supplied allen head bolts and tighten , I cannot remember torque , maybe 30-50 not sure.
hope this helps
Don
Old Jan 5, 2002 | 04:10 PM
rfat16's Avatar
I finally got it all figured out at about 1am last night. Thanks for the help ICULOKN. I took it for a spin last night WOW, what a difference. Thanks JL.
Old Jan 5, 2002 | 04:21 PM
ICULOKN's Avatar
RFrat16,
So now you have a lower pulley (what size?) chip, Ram air kit?
Old Jan 5, 2002 | 04:25 PM
rfat16's Avatar
#4 pulley..... Everyone says they'll run 12's like this but i don't think its possible. The tires don't hook up at all.
Old Jan 5, 2002 | 04:26 PM
ICULOKN's Avatar
U will run 12's easy is u get it off the line, You do have a chip right?
Old Jan 5, 2002 | 04:27 PM
rfat16's Avatar
yep a diablo burned to perfection it seems so far
