Help with new mods!
Old Dec 10, 2001 | 04:01 PM
DAVER716's Avatar
Help with new mods!
Anybody with any of the following have any install tips for me?Just got a pkg from JDM with Fip chip,4LB Lower Pulley,Boost Bypass Valve,Line Mod Valve,Crankcase Breather,and NGK's.I got some spark plug install tips from Chuck's L page w/pics,it seems pretty informative.Planning to install this Wed.,then a trip to the track Wed. nite.Any help will be appreciated!THX,Dave.
Old Dec 10, 2001 | 06:49 PM
LIGHTNINROD's Avatar
Well, changing from one tuner's pulley to another should take about 30 mins--using jack stands. The chip exchange, another 15 mins(no cleaning required). Boost by-pass and cr/case(oil cap?) breather--maybe 5 mins. The line mod--d/k about it.
The spark plugs?????--man, they intimidate the he!! out of me. I've changed many a plug on other engines thru the years but I can't get my self to tackle that job--it might take you the rest of the day?
Good luck,
Dan
Old Dec 10, 2001 | 07:17 PM
ICULOKN's Avatar
first time on plugs was 2 hours, main thing to remember is the 3rd one back on the drivers side requires a 1/4 breaker bar to break loose the 7mm nut holding the coil pack in. 2nd time, 1 hour!!!
Pulley, well psp does not use a factory gage, does the JDM 4lb use the factory gage? other than that it should be easy.
Line valve about 1 hour, plus alot of cleanup if your not careful!!!
The rest are easy and should only take about 30 min total!!!!
Old Dec 10, 2001 | 09:37 PM
DAVER716's Avatar
Thanks guys,I installed the PSP pulley,so I don't think replacing it with the caged JDM will be too tough.Breather & boost bypass look easy enough too.Same for chip swap,I was a little worried about the Line Mod Valve but,Evilguy hooked me up w/some pics.Looks easy enough.I also got some pics install info on plugs from Chuck's L page.I'll let you know how it goes.-Dave.
