sub questions
Old Dec 10, 2001 | 12:45 AM
svtmike24's Avatar
Thumbs up sub questions
https://www.onlinecarstereo.com/cara....asp?sku=11472
would this go with 2 jl w3's
Old Dec 10, 2001 | 12:52 AM
Lightning Boy's Avatar
Looks like it is a monoblock amp. I think you would need a 2 channel amp for 2 speakers.
Old Dec 10, 2001 | 01:06 AM
MadNess's Avatar
personally I would go
With the JL 500/1 monoblock amp, I run two JL 10w3d4 subs.
Old Dec 10, 2001 | 01:12 AM
Can you run two off a monoblock? I would love to add a second 10" Infinity Kappa Perfect in my little truck, but have a Apline monoblock amp.
Old Dec 10, 2001 | 01:19 AM
whitetoast11's Avatar
if your running 2 jl 10w3's you'll probably need more power,, check the max power rating of the subs on their online sight,, you'll need a 2 channel amp. Look at the rms ratings too,, peek wattage doesn't mean jack.
Old Dec 10, 2001 | 01:25 AM
J15BIG's Avatar
you can run as many subs as you want off a monoblock. just wire the subs together inside the box. i personally have 2 JL 10W3D6's in my truck run off of a JL 500/1.
heres a link that shows you how to wire all three types of W3's(D2,D4,D6) and it gives you the impedence presented(page2 for D2 subs, page4 for D4, and page6 for D6):
http://www.jlaudio.com/subwoofers/pd...10W3Normal.pdf
i recommend 2 10W3D2's and wire them so they present a 2ohm load. this way, you will get max performance from your amp(the rockford) without overhearting it. overheating is caused by going lower than the minimum impedence for a certain amp, i think. overheating can also be caused by poor ventilation. anyway, i could go on for days about what you should and shouldnt do so im goin to stop now.
anymore questions just ask
joe
Old Dec 10, 2001 | 01:27 AM
Deus's Avatar
Woh there fellas. That amp will work great if your subs have dual 2 ohm coils (d2). Check out the wiring faq on jl's site. You would parallel the coils on each sub then parallel the subs together. You DO NOT need a 2 channel amp. Also, max wattages are typically marketing crap. It is best to go by RMS ratings.
Old Dec 10, 2001 | 01:44 AM
i'd still go with a 2 channel amp in order to wire it to the speakers ,,, stock speakers on these L's suck
plus if you ask me, 2 jl10w0's are more then powerful enough to shake everything loose in the truck, plus they are cheaper. its not that big of a truck cab, plus you can run up to 160 rms to each one @4ohms no problem
Old Dec 10, 2001 | 02:27 AM
svtmike24's Avatar
watts
on the jl 10w3's it says the max watt is 250 so the 500 amp should be could right
Old Dec 10, 2001 | 03:24 AM
slvrbolt's Avatar
just put in two amps it will solve your problems. i am putting in three amps in my L (in the bed). two 12's, dvd, the whole nine yards. will post pictures when done.
