two dead cylinders, definition please
Old Dec 9, 2001 | 12:45 AM
Probleminfected's Avatar
ok
here is all the other info on what happened
https://www.f150online.com/forums/sh...threadid=58928
Anyway, I was thinking that two dead cylinders is when the piston rings are fried or the valves are fried, am I right?
Old Dec 9, 2001 | 12:53 AM
JeffsLightning's Avatar
Two dead cylinders means that no power is being made in those two. Could be fuel(doubt it) could be spark(most likely) or could be something with the valves or rings(doubt it). Jeff
Old Dec 9, 2001 | 12:56 AM
ok well the tech at the shop told me it wasn't the plugs so it either has to be the valves or the rings, and i really doubt it being the fuel
Old Dec 9, 2001 | 01:00 AM
Was the engine still idleing? If so was it making any weird noises? These 5.4's are prone to spinning rod bearings... I have not heard of any that have had prob;ems with rings or valves killing a cylinder. Jeff
Old Dec 9, 2001 | 01:05 AM
yeah the engine would still idle, but barely
you know i bet i really bet that they are just lying to me to get more warranty money, the plugs are probably just bad and they didn't even look at them just hooked up the truck to the computer and it told them it had to dead cyclinders
Old Dec 9, 2001 | 01:18 AM
2 dead cylinders is not good. Hold off on accusing them of any wrong doing. See what they say. Hopefully it's not as bad as it sounds...good luck. Jeff
Old Dec 9, 2001 | 01:21 AM
well i really don't care what they do as long as its fixed by wednesday
and haha they don't drive it to much, buttheads
Old Dec 9, 2001 | 08:36 AM
A-Lightning's Avatar
Unhappy 2 dead cylinders!
Could be a lot of things!
First place to look would be the spark plugs! (already done)
2nd would be the coil packs! (probably) (hopefully!)
3rd would be fuel!
It gets bad from there!
Could be...valves, broken valve springs, rings,blown head gasket, bad cam shaft! etc.
From what i am hearing, the most common is spark plugs or coil packs!
Good luck!!!
Albert
Old Dec 9, 2001 | 01:16 PM
Y2K 7700 4x4's Avatar
"...These 5.4's are prone to spinning rod bearings..." (JeffsLightning)
Really?!?
A quick search of "rod bearing" in the Engines forum netted 17 references -- and a quick search of the first page of the first 6 sources didn't produce any results in support of your statement.
If there's a problem (with rod bearings), please help us understand.
Old Dec 9, 2001 | 03:37 PM
i'm really hoping they don't tell me i new a whole new engine put in.
what do you guys think they will tell me ?
Old Dec 9, 2001 | 03:50 PM
Don's Bolt's Avatar
If the spark plugs are Ok my bet is bad coil pacs.
Old Dec 9, 2001 | 05:24 PM
anybody got a pic of bad coil packs ?
