installed jdm PCM and everything got weird!
Old Dec 7, 2001 | 12:49 AM
Probleminfected's Avatar
Thumbs down installed jdm PCM and everything got weird!
ok
So I installed a jdm PCM today, the engine was pinging badly so I put some octane booster in (the outlaw and added the full 22gallons), so I was testing it out and I still hear the knocking, then vibrations bad. So I slow down, but no good, so I take out the chip (with the battery off) and now I know the engine is misfiring.
What the hell is wrong, it is a spark plug or what? i rather not take my car to the shop, i work a 8-430 job hard for me to take it in
please help me
David
Old Dec 7, 2001 | 01:09 AM
captainoblivious's Avatar
first did you clean you contacts off good before installing the chip?
Next I'd say disconnect you battery and let the power drain so that the computer is forced to reset itself then see if the trucks still acts up.
If everything is normal, install the chip again and make sure it has good contacts. Then watch and listen like a hawk. Anything else go wrong give Jim a call to get it taken care of.
Old Dec 7, 2001 | 01:10 AM
blownlightning's Avatar
You may have burnt an electrode off one of the plugs.
Old Dec 7, 2001 | 02:16 AM
Thumbs down
ok i let the battery drain, still messed up.
i wounder if it is the octane booster i put in?
if not it is a spark plug, because i can tell its firing weird
David
Old Dec 7, 2001 | 06:05 AM
PFA's Avatar
PFA
Did youput the plug back on the computer real good? Try taking it off and re-installing it.
Old Dec 7, 2001 | 08:07 AM
Don's Bolt's Avatar
David
Like PFA said make sure you check where the wire harness screws ino the back of the Processor. Check to see if any of the connectors are bent, and also make sure it is connected properly.
Old Dec 7, 2001 | 08:30 AM
usahooters's Avatar
detonation
How long did you run with the pinging sound going on? Did you back off or give it some more? If you ran it very hard or for very long like this you more than likely need some new plugs. You will be able to tell by looking at them when you pull them out. It was trying to tell you that its running to lean. The octane booster should have helped but it was probably to late. I would have mixed it heavy like one can and 8 to 10 gallons of gas. If you ran lean for to long your plugs will be burnt. Never keep running with a detonation problem back off and save the motor. Either get some good gas or have the chip richened up for the cool dense air.
Old Dec 7, 2001 | 09:48 AM
Silver-Bolt's Avatar
Sounds like you burnt the electrode off the plug or plugs. Pull them out and check each one. Might as well swap out the platinums while you are doing it. Don't be surprised if your plugs have turned purple. The octane boost will discolor them.
Old Dec 7, 2001 | 10:09 AM
Silver_2000's Avatar
Probleminfected
JDM doesnt post here often... Post this on SVTperformance.com forums so he can offer advice
Doug
Old Dec 7, 2001 | 10:45 AM
usahooters's Avatar
give em a call
I think you owe it to JDM and yourself to call them and talk to directly to him. I'm sure that he will be more than happy to help you.
Old Dec 7, 2001 | 09:30 PM
i called up jdm tonight, found out i'm running the right program for my area (j69), he said the chip might have been just a little bit off, i had a bad tank of gas, or the chip was messed up.
so i'm taking the truck in to the dealer tomorrow to get new plugs in (because i don't want to pay for new better ones) and get the clunk in the control arm fixed too. when i get it home i'm going to install the chip again and jdm told me that if it still messed up then he is going to send me a loaner chip (thats really kick *** of him).
so everything is cool, plus i'm getting the clunk fixed which i've been meaning to do anyway
David
and thanks guys for the suggestions
Old Dec 8, 2001 | 01:43 PM
Unhappy
ok
i took the truck in today, got the bad news. Two yes two dead cylinders. Ouch that hurts
i guess i'll be driving my moms car to work for awhile damnit
this sucks, they better not mess around with warranty BS
David
Old Dec 8, 2001 | 01:49 PM
Hamma's Avatar
doh that sux
Old Dec 8, 2001 | 02:49 PM
Spiro99SVT's Avatar
Originally posted by Probleminfected
ok
David
What were your plugs like ??
Old Dec 8, 2001 | 03:01 PM
plugs were fine, atlest thats what they told me. they could be pulling a scam to get warranty money from ford. Either way as long as it fixed i could care less, except for me having to drive my moms lincoln around for awhile
and no my mommy didn't buy the truck for me haha
