Exaust tip help
Old Dec 8, 2001 | 03:12 PM
socallightning's Avatar
Exaust tip help
Ok I know this is an easy one :) but I did not want to start pounding with a hammer till after I asked.
I am trying to remove the factory tips and wondered if there was some trick to it. I removed the 4 nuts and loosened the clamps.
I can wiggle the tips a little but they will not slide off. I was wondering if there was some kind of tab or other doohicky! that I need to loosen to remove them or was I lucky to get one that was over tightened at the factory and now has a dent in it so it will be a real BITCH to get off :(.
I spent 20 minutes shaking tugging and twisting on the things and was digging out the 5 lb influener to tap it off with but wanted to ask :) heheh
Oh ya I did search but the 2 posts it returned did not help me out in the least
Thanks agian for your time
Old Dec 8, 2001 | 04:30 PM
jarmstro's Avatar
Unhappy Removing tips
socallightning,
Take a big hammer...... really they are a pain to remove. I removed mine and put on BaBolt's tips and might add they look wonderful.
My stock tips after removing the U-bolt seemed loose and I pulled on them shooked the hell out of them and still didn't come off. So.... I took my big hammer a big bladed screwdriver and started tapping the edge a little at a time till they came off.
Since I was replacing them I wasn't worried about screwing the old ones up. I might add I didn't screw them up.
The new tips were easy to put on and as I said above they look wonderful.
Are you replacing the old ones with something?
Good luck!!!
Old Dec 8, 2001 | 04:45 PM
WCFan's Avatar
Smile
You can cut or break the weld that is on the top side of the exhaust tip to pipe interface just behind the U-bolt .
Old Dec 8, 2001 | 04:58 PM
yep I am making a new tip for it I posted pics a couple of days ago I needed the old one off to get some mesurements
the pics are not the best and the tip is just slid over the stock pipes now I wanted to make sure I liked the look before I ripped the old ones off.
Its #8 polished stainless steel
