Ford 4.10 Gears
I HAVE A SET OF 4.10 GEARS FROM FORD AND I NEED TO KNOW IF I SHOULD USE A PINION SPACER OR A CRUSH SLEEVE WHEN INSTALLING THE PINION. I HAVE HEARD YOU HAVE TO USE A PINION SPACER ON 99 AND NEWER 9.75 REAR AXLES
TRY DOING A SEARCH FOR "4.10S"
I KNOW YOU ARE GONNA NEED SOMETHING THOUGH. I THINK YOUR CAPS ARE LOCKED JUST LIKE MINE. BUT I JUST FOUND IT. There. Cool.
Tundra's blood pressure drops as a result of the ease of reading his own lower case typing.
It is located just to the left of the 'A' character on your keyboard.
