Bastard trim screws!!!!!
Old Dec 4, 2001 | 09:29 PM
soap's Avatar
Question Bastard trim screws!!!!!
This might be the dumbest question ever asked on this board but here goes.......
How in the hell do you get those plastic trim screws out of the piece that goes over the fan shroud. I tried to just unscrew them but they didn't back out and the heads of the screws are rounding out. I tried this very carefully and still no success. I even tried to push up on the screw while trying to loosen them
You guys that have gone to electric fans or something had to remove this piece so can someone help me out here. RobG even painted his black (which BTW looks really trick).
Sorry so long.....Joe
Old Dec 4, 2001 | 09:31 PM
CrazyFoo's Avatar
I had to break a couple of mine. Either do that or you have to very slowly screw it out, and lift the screw driver up as you do it, otherwise the screw will just keep on spinning.
Old Dec 4, 2001 | 09:36 PM
MRBBQMAN's Avatar
get a bag of them at autozone for a couple of bucks and rip them out like a bad tooth, or something
ASVTFordBoy's Avatar
Angry They are A Bas@#*%
One thing I learned on my last F150 is if you put very much down force on the screws when you are trying to unscrew them, they will strip out and will be next to impossible to get out. When I removed the one in my L, I put just enough down force on the screws to keep the screwdriver from popping out of the crew head and they came out with no problems. Once they're stripped you basically have to just pull them out.
Old Dec 4, 2001 | 09:40 PM
Neal's Avatar
Cool
HI!... Yes they are a pain to get out. But if you use a very small "SLOT" screwdriver and lift up under the head of the plastic screw as you unscrew it with the other, it will come out with no problems. I replaced all mine with wall anchors and used stainless steel robinson headed screws.
Old Dec 4, 2001 | 09:59 PM
soap's Avatar
Thumbs up Nice work
Thanks guys....I'll give it a shot
Old Dec 4, 2001 | 10:03 PM
MXRacer's Avatar
First, I gotta say I was a little disappointed by this thread because I thought the topic was "bastard TWIN screws"...as in superchargers. Other than that thought...
Another option to consider is to use the same small flathead that Neal was talking about, but instead of lifting the collar up with it...use it to push in against the threads on the "collar" so that the teeth of the actual screw have something to grab a hold of. Once you get it out, then follow the oh-so-knowledgeable MRBBQMAN's advice and buy new ones to replace the hackedy-hack-hacked ones you just took out.
BTW- I still haven't followed this last step.
Hope this helps. Later...
GK
Old Dec 4, 2001 | 10:05 PM
soap's Avatar
Wink blow or screw
Thanks MX....sorry about the confusion
Old Dec 4, 2001 | 10:21 PM
Don's Bolt's Avatar
Hey Soap
If you have a little eyeglass screw driver that will work good to help get the screws out. Also the ones bye the hood latch if your hands are small enough you can squeeze the tabs underneith to help get the threads to grab.
Old Dec 4, 2001 | 10:22 PM
MXRacer's Avatar
On my end anyways you're pic posted every time...
...but something I will give you a heads up about before the UBB ****'s wake up tomorrow morning and catch wind of whats going on is that there is a forum here on f150online specifically designed JUST so you can fool around with and fine tune your sig, so you don't have to do it here, and anger all the Lightning Giants that think a new response has been posted. I think the forum is called "Testing 1-2-3".
Later...
GK
Old Dec 4, 2001 | 10:29 PM
soap's Avatar
Unhappy oops
Thanks again MX.
Sorry administrator guys, it won't happen again. I was unaware of the testing 1-2-3 board. I erased my extras already.
Joe
Old Dec 4, 2001 | 10:40 PM
Silver-Bolt's Avatar
Side cutters. Actually there is a special tool made for removing those and the christmas tree clips. It works pretty slick. I will post a pic as soon as I get my digi-cam.
Old Dec 4, 2001 | 11:00 PM
soap's Avatar
Can you also post where you got "the tool" from.
Old Dec 4, 2001 | 11:12 PM
Masterloggie's Avatar
Get you about 18 inches of monofilament fishing line. Wrap it under the collar. Pull up on the collar with the line and unscrew the plastic screw.
