Djy?????
Old Nov 28, 2001 | 12:37 AM
ICULOKN's Avatar
Djy?????
Hey you have the 3/4 kit and a 2in a arm right? Did you have to C-Notch the rear or did you do it for a better ride?
Old Nov 28, 2001 | 01:29 AM
DJY's Avatar
DJY
Lightbulb
ICULOKN
This is all I came about to installing the many kits I have installed on my Lightning. When I first got my Lightning there were no kits for Lightning. I went to this site no one lowered there Lightning as low as I did. I first went with the Bell Tech 3/4 after calling Bell Tech and asking an Service manger if the Bell Tech Kit would work on a Lightning he said it would work so I installed it with a friend. After that I noticed the rear was lower than the front I really didnot like the look so I called around and found A-arms which worked after being advised from Sport Truck Tech. All in all I think I was a Guinea Pig for all these companies cause no one else installed what I did and put 2 different kits on one truck. As for the C-section on the rear I could not handle the bottoming out on the rear end while hitting bumps and pot holes and cruising at high speeds.
I really like your truck I wanted to tell you that after you posted a picture a week or so ago.
Hope This Is Some Help, djy
Old Nov 28, 2001 | 04:56 PM
ICULOKN's Avatar
Thanks for the comment on mine truck, it does mean alot coming from guys with Bad A$$ L's. I like how low yours sits. I may do the A-arms next, Mine does bottom out alot to so I may have to do the C-notch as well!!! Thanks again!!
Old Nov 28, 2001 | 06:07 PM
LeenSVT's Avatar
I have a brand new DJM c notch still in the box I will sell you. I had the Bel Tech 3/4 on my L and sold the truck before I had a chance to install the c-notch. Let me know if you are interested.
Thanks Gary
