clunking front end
Old Nov 1, 2001 | 05:39 PM
frank2's Avatar
Angry clunking front end
I have a little problem with the front end popping while turning hard right an d when driving out of my driveway forward turning right,what the heck could this be?? I just got done converting her to JL gear and I hope I don't have to take it off for service, so service is what I want to avoid!
Old Nov 1, 2001 | 06:57 PM
kylightning's Avatar
they all make the clunk. damn it is kind of embarassing, i think i need to get mine fixed too.
someone ,maybe herb washer and the washer stops this.
i'm sure someone here will give you a good explaination and a solution.
Old Nov 1, 2001 | 07:40 PM
2000Black's Avatar
Oh boy, here goes....
This is a known issue with the 1999 and 2000 Lightnings. The driver's side lower control arm has a slot it in, which causes the bolt to slide around in the slot as a result of the huge tires and wheels on our beasts. There is a Ford TSB for this issue. The TSB # is 00-25-8. It involves installation of a "toothed" washer to grip the control arm with more force. If you are lucky you also get the cam kit necessary for front end alignment and the alignment done for no cost. My experience with the fix is that it has worked. Others will chime in on this topic I'm sure. Your mileage may vary. Good luck with your truck!
Old Nov 1, 2001 | 07:42 PM
99WhiteBeast's Avatar
frank2,
Do a search on "Herb's Washer" or "Clunk Fix" and you'll find a wealth of information on the subject.
Basically the lower driver side control arm bolt is sliding around. The washers from Herb fix the problem and you can install yourself-no problem.
Take a look at the bolt and you'll be able to see how it has moved.
Old Nov 1, 2001 | 07:55 PM
super dave's Avatar
Just try putting some grease on the steering stops on the lower control arms, this will solve the noise part. Then add Herbs washers to make it solid.
Old Nov 3, 2001 | 12:22 AM
frank2's Avatar
THANKS GUYS
Old Nov 3, 2001 | 12:24 AM
BfB's Avatar
BfB
Banned For Rules Violations
2001's do it too.
Old Nov 3, 2001 | 01:41 PM
slapshot's Avatar
I just noticed the front end clunk on my 99 when I am making a somewhat sharp turn and hit a speed hump or anything like that. Most of our Crown Vic cruisers do that after about 15-25k miles too. The Crown Vics are actually worse sounding than my L. I am going to have mine checked when I take it in for the supercharger/intercooler recall.
Old Nov 5, 2001 | 11:43 AM
action 911's Avatar
Post
E-mail me here, jacksonherb@hotmail.com.
I'll explain the problem and two ways to fix it.
Herb
Old Nov 5, 2001 | 12:01 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
garnish
Old Nov 5, 2001 | 02:17 PM
action 911's Avatar
Question
Speeding Bob,
Get ahold of me I would like to know how that happened. What does the bolt look like? Did it shear off?
Herb
Old Nov 5, 2001 | 02:22 PM
Herb,
The Bolt DID NOT sheer off.
I snapped the photo when I removed the washers in preparation for trading my 99 for a 01.
All is good. Washers are fine. Aren't they
Sent ya a message too.
Old Nov 5, 2001 | 02:30 PM
97GreenLariat's Avatar
My 97 Supercab does this too -- Would it be the same problem?
Old Nov 5, 2001 | 03:27 PM
action 911's Avatar
Thumbs up
Bob ,
You get me on that one! It was nice talking to you.
I'm glad they held up for you. This is the first that I have heard of someone taking them out of one truck, and putting them into another. Enjoy your new ride.
Herb
Old Nov 5, 2001 | 03:43 PM
Herb,
Nice talking to you also. Thank you for the follow-up!
For those of you that my be concerned about the image above, rest assured the washers are FINE.
The indentations are from being torqued REALLY hard.
Any questions, please feel free to email me.
Bob
