Sal?
Old Oct 10, 2001 | 11:38 PM
andrewjhaley's Avatar
Sal?
Hey, http://www.powersurgeperformance.net...pexd.asp?id=36
that new valve body, if i were to get that, could i guarentee longer tranny life
and instalation, it says i can leave the tranny in, but do i have to drain any fluids, what is the procedure
Old Oct 10, 2001 | 11:45 PM
LightningTuner's Avatar
It's very simple to install. It's easier than doing a shift kit or line mod valve because there is nothing to take apart. You drop the trans pan, remove the filter, unbolt the old valve body and bolt the new one in. All you really need special is an inch pound torque wrench. We include very detailed directions. It will help extend trans life by giving you less slip on the shifts, which results in less clutch pack wear as well as less heat.
