Torn on pullies
Old Oct 9, 2001 | 07:01 PM
wrightlightning's Avatar
Question Torn on pullies
Just want to poll the "audience". I currently have the PSP 2-3 lb lower pulley. I want to go with more boost...so do I get the LFP upper pulley to compliment the PSP lower, or go with the JL 4lb lower with no upper? Is the LFP really a 2 lb pulley (someone stated on another thread it was only 1 lb)? Thanks for any responses.
Old Oct 9, 2001 | 07:06 PM
blownlightning's Avatar
I was looking for the same responces yesterday not to many replies, if I obtain any info I will e-mail you. BL
Old Oct 9, 2001 | 07:08 PM
I was not aware, BL. Thanks for the reply. I will do the same.
Old Oct 9, 2001 | 07:16 PM
Skank Dog's Avatar
I think I was the one that said it was a 1#. I bought it from LFP and have been told by several people that it was a 2# pulley before buying it. But upon having the lower installed in Ennis by JDM, Shawn stated that in fact it was only a 1#! After looking at the upper on JDM's truck, it was obvious his was quit a bit smaller than the metco I have. His upper is a 2#! I firmly believe JDM knows what they're talking about. Just relaying the info. I was told......hope this helps.
Old Oct 9, 2001 | 07:23 PM
Skank Dog's Avatar
FWIW-I did notice a 1.5# increase with the upper. My boost gauge use to only run up to 8.5 lbs. After the upper it went right up to the 10 lb. mark, but never right on it or past it. Now with the lower installed, it goes past the 10 lb. mark into the black!
Old Oct 9, 2001 | 07:54 PM
Spiro99SVT's Avatar
Go with the lower pulley. If you add a smaller upper pulley, you will loose some belt to pulley surface area, and inviting the risk of slippage into the picture.
Bigger pulley down low only add more belt/pulley surface. Hope this helps.
Old Oct 9, 2001 | 08:15 PM
Totaled's Avatar
Thumbs down
I have the LFP upper and I don't believe it is 2# as advertised!! When I went to the JL 4# with the stock size upper the truck felt stronger than the 3# with the advertised 2# upper!! Take Spiro's advice and go bigger on the bottom!
Old Oct 9, 2001 | 08:26 PM
rscoleman's Avatar
Why not both?
Old Oct 9, 2001 | 08:30 PM
Totaled's Avatar
Thumbs up
Originally posted by rscoleman
Why not both?
I couldn't agree more
Old Oct 9, 2001 | 08:35 PM
99svtlightning's Avatar
I have the ASP 1.5# upper and JL 4# lower. I would do both, but if you're only gonna do one go with the 4#.
Old Oct 9, 2001 | 10:51 PM
DL's Avatar
DL
Thumbs up
I went with a 4# JL pulley...
Low end torque is AWESOME and it really pulls strong through the whole power curve..
I am very happy with my 4# JL pulley.. I may get an upper in the future
Old Oct 9, 2001 | 11:16 PM
Wow! Thanks for all of the replies. It looks as if I am going to have to get in touch with JL (again)! My main concern was building up too much heat or over-spinning the blower, and with the upper I could replace it to the stock piece for every day driving. I guess I could get the 4 pounder and use the upper for just strip action.
Thanks again.
