Denso Plugs Dyno Results
Old Oct 1, 2001 | 12:54 PM
HIGH ROLLER's Avatar
Arrow Denso Plugs Dyno Results
Here are the results from my dyno last friday with the new Denso 1 stage colder IT20 plugs.First of all we made 2 runs before then we put the new Denso's in about 1.5 hours than started truck to bring the engine up to temperature and they made 2HP and 3ft.pounds of torque all through the power band.My air-fuel also went down from 12.0 to 11.8 because of the colder plug i believe.This is far from what the magazine said and only time will tell if they hold up under all climate conditions!They seem okay so far but not sure if i will shell out $100 next time around!
Hope this helps!
Matt
Old Oct 1, 2001 | 01:09 PM
Redneck Ferrari's Avatar
Were your "original" plugs NGK, Splits, or were you really using the original Autolite Platinums?
Thanks for the post
Old Oct 1, 2001 | 01:12 PM
Totaled's Avatar
Thumbs up
Thanks Matt! I appreciate your time and effort!!
Old Oct 1, 2001 | 01:16 PM
Silver-Bolt's Avatar
You need a dyno in your garage. Your dyno guy must love you. Thank you for the info. $100 for plugs ouch!
Old Oct 1, 2001 | 01:27 PM
I was using the stock platinums in my truck!
Old Oct 1, 2001 | 01:41 PM
dogleg's Avatar
Thanks for your help and for the money you spent teaching all of us!!!
Alvin
Old Oct 1, 2001 | 01:55 PM
Spiro99SVT's Avatar
Matt,
Great work. Before you E-mailed me, I was expecting a slightly bigger gain than that.
As you said...the real test will be on the track. Keep up the good work,and dont let a few keep you from posting your finds.
Old Oct 1, 2001 | 04:35 PM
NeedFourSpeed's Avatar
I would also like to thank you for your contribution of time and effort for this and your exhaust experimentation
$100 for 2rwhp may sound like alot to some, but, HP doesn't come cheap after a certain point. Also, I know of several other mods that offer less HP/$ ratio.
Thanks again.
Old Oct 1, 2001 | 06:46 PM
Fast Gator's Avatar
Thanks for the effort to test and to report your finds. $100 for plugs....think I 'll just buy two cases of Budweiser, a bottle od JD, fill the Lightning up with gas and pocket the rest. But hey, that's just me. Thanks again for your report
Old Oct 1, 2001 | 06:50 PM
Old Oct 1, 2001 | 07:43 PM
LOCOSVT's Avatar
Thumbs up
Matt;
Thanks for the info...2 hp here and there add up. If they are durable, then it's worth it. Usually a gain across the board also smooths out the powerband.
OTOH, look at it this way...If you had gained 40 hp, then you would have to put up with all the posts accusing you of lying, BS, not knowing how to dyno, etc...
Old Oct 1, 2001 | 08:50 PM
collins8's Avatar
Banned
Matt,
Thanks for all the info!!
Rob
Old Oct 1, 2001 | 10:05 PM
Bad as L's Avatar
Talking
Good work Matt
Ummm, so whats goin on the dyno next ?
thanks again
Dale
Old Oct 1, 2001 | 11:01 PM
Lightning Bob's Avatar
Thanks for all the research!
Matt,
It's great you are checking out all of these things for us. Thanks for letting us know your results.
Do you plan to come over to Byron for the LLNESS Fall Truck Shootout this Sunday and the debut of Rob's newest mod? Hope you can make it. If not, maybe we will see you again on Saturday at Terry's place.
Lightning Bob
Old Oct 1, 2001 | 11:18 PM
Bob,
I am having some tranny issues i believe so i probably will not make it to Byron but i will try to see you saturday morning at Terry's to see the finished product!
Matt
