How Do These Times Look? (1/8 mile)
Just go back from the track and ran a best of:
2.054 60ft
8.644 ET
83.19 MPH
I did have one problem I had my PSP set on the street program and on my 2-4 run I was loosing boost on the 1-2 shifts. I know
hitting the rev limiter caused the problem but is there anyway I can have the rev limiter bumped up so this won't happen again. I know I could remove the bypass line but I only want to do this on the track. I could of run better because my 60ft times were droping with each run.
Just for comparison my last run I set the chip to the stock program with improved shifts(towing) and here ar my times (I had boost for the whole run):
2.073 60ft
8.864 ET
80.47 MPH
So PSP street program gave me a .2 reduction in ET and 3 MPH.
2.054 60ft
8.644 ET
83.19 MPH
2.073 60ft
8.864 ET
80.47 MPH
Digging through our 01 timeslips, I found a few with matching 60fts and the same mods. Your 8.64 1/8 mile should be about a 13.2 in the 1/4 and your 8.86 should be about a 13.6. No doubt with better 60fts you should be on the 12-13 second border.
Sal if you could shoot me an E-mail I need to talk to you about loosing boost on the 1-2 shift. Other than that the chip kicks ***!
lightning-01@home.com
Boost Dump Soleniod
You can just plug the solenoid back in when you not at the track, although I don't know that it hurts to just leave it unlpugged. It only takes a sec. I just left mine unplugged and have had no problems.
